Old 05-26-2022, 10:28 PM   #1
Extension cords
How safe, or dangerous, is it to run an extension cord in my 2022 FR Wildcat 5th wheel. It not a matter of more power its where. We are full timers and I would like to work at the table. There is not any power close enough for my laptop. There is a plug behind the recliners but it’s two sockets and two chairs.
Recommendations???
Russellvh is offline   Reply With Quote
Old 05-26-2022, 10:35 PM   #2
A laptop does not draw a lot of power so it should not be an issue at all to use an extension cord. A space heater on the other hand would not be suitable since they typically draw high amperage. I use extension cords all the time in my 5th wheel for my tablet and laptop. Just don't plug alot of devices into a single extension at the same time. Even so, you would most likely pop a breaker or blow a fuse if overloaded..just like at home.
__________________________________________
2014 Spartan 1032
2015 GMC 3500HD Denali 4WD/Duramax
RockyMtnMarty is offline   Reply With Quote
Old 05-26-2022, 11:03 PM   #3
You should be ok. I'd go with a three prong heavy duty extension cord.
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 05-27-2022, 09:27 AM   #4
Jim34RL's Avatar
I use a surge protected extension cord for my electronics. These tend to be a little more costly than your standard extension cord, but they protect my computer and electronics. I tend to use these in my home for all my electronics needs also.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
Old 06-20-2022, 07:00 PM   #5
Chardagha's Avatar
Most of my adult life, I have not known much about electricity flow, but have learned much in the last 5 years. If you run an extension cord, make sure it is no less than 3 phase, 12 ga. cord. And as Jim suggests, a surge protected extension is a smart investment. But be prepared to pay $30+ for a good one.
Chardagha is offline   Reply With Quote
Old 06-20-2022, 07:16 PM   #6
Flybob's Avatar
Do you mean 3 wire ( two wire and gnd)?
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 06-20-2022, 07:22 PM   #7
3 phase? I think you mean 3 conduter. Your laptop probably has a 2 conductor cord, get a 6 foot cord and you will be fine.
Capacitor is online now   Reply With Quote
Old 06-20-2022, 07:31 PM   #8
Oaklevel's Avatar
I would get a good plug strip with surge protector built in for a laptop. The cords come in different lengths.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 06-21-2022, 11:31 AM   #9
Chardagha's Avatar
My bad! I did mean a “3 wire” cord, not 3 phase. I should have said, a grounded 12 ga. cord. Sorry!��
Old 06-21-2022, 01:02 PM   #10
I've used a variety of extensions cords in the RV, just like I would in a stick and brick house.
--2005 F350 Superduty Crewcab, 6.0, 4wd, short bed, 3.73 gears;
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
phillyg is offline   Reply With Quote
Old 06-21-2022, 01:46 PM   #11
Recommendations???
If you're just going to use it for a laptop then any household extension cord will be fine . very low draw from a laptop
MR.M is offline   Reply With Quote
Old 06-21-2022, 01:47 PM   #12
Exactly as safe or dangerous as an extension cord in your (or any) house.
NavyLCDR is offline   Reply With Quote
Old 06-22-2022, 11:22 AM   #13
Jim34RL's Avatar
Except the cheap household 15AMP extension cord will not protect from an electrical surge if one was to happen.
As an example, last week we where set up in a RV park in MI. A severe thunderstorm was taking place and all of the 120V power shut off in the camper. The power returned in two minutes and everything was back to normal for us.
What happen? Our surge protector shut off the power due to a surge in the campground power supply. I did have to reset the power strip in the camper for the electronics also.
Better safe than sorry.
Jim W.
Old 06-22-2022, 12:39 PM   #14
so have a surge protector for whole rv no need for a separate one on extension cord . but i say do what makes you feel safe . my bulldog does the job for camper .
