Old 01-30-2017, 08:47 PM   #1
Fifth Wheel towing
Hello, when towing a fifth wheel, can I leave my tailgate on and just lower it before hooking the fifth wheel up and then raise it once it is on. Thank you
bedelstein is offline   Reply With Quote
Old 01-30-2017, 08:51 PM   #2
BandJCarm's Avatar
Leave it on.
Make SURE you raise it back up before moving and turning!!!
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 01-30-2017, 08:52 PM   #3
Thank you
Old 01-30-2017, 08:57 PM   #4
It depends. If we back up square on to our fifth wheel, we have about 2" clearance between the down tail gate and front of trailer. If we are not square on, we stop and raise the gate after we are clear of the pin, before we engage the pin in the hitch. Try it and be very cautious.
2016 Prime Time Crusader 322RES
2016 Ford F250 6.7L Diesel, Crew, 4X4, SRW, 3.55, Platinum, Ride Rite air bags
Reese Elite 18K Hitch
Nights camped 2016=47 2017=67 2018=53 2019=121
dennisewitte is offline   Reply With Quote
Old 01-30-2017, 08:59 PM   #5
Thank you
Old 01-30-2017, 09:21 PM   #6
keith52's Avatar
Yep, that's what I have done for 15 years.
2014 Chevy CC Duramax 4X4 Long Bed
2017 Cedar Creek 36CKTS
MORryde independent suspension with disc brakes
keith52 is offline   Reply With Quote
Old 01-30-2017, 09:30 PM   #7
Thank you
Old 01-30-2017, 09:36 PM   #8
Now a "Top Member"
EdJunior's Avatar
Yep. It's never been a problem for me. Just be careful, take your time, and know what your clearances are.
Ed and Sharon
2010 Wildcat 28RKBS
2019 Ford F-250 XLT - AWESOME Truck!
EdJunior is online now   Reply With Quote
Old 01-30-2017, 09:43 PM   #9
Thank you
Old 01-31-2017, 08:30 AM   #10
5er_tom's Avatar
As an alternative you could replace the existing tailgate with one of the aftermarket units that have a deep V in them. No need to lower it when hitching and you can easily watch as you line up the truck and 5th wheel.
Love my Wildcat 295RSX!
Tom & Renée
Durham, NC
2015 Wildcat 295RSX
2018 Ford F-350, 4x4, Diesel, CC, Long Bed
5er_tom is offline   Reply With Quote
Old 01-31-2017, 08:49 AM   #11
Only thing there is I am trying to keep the stock gate and back up camera if possible,and if doing the way I described works I would rather do it like that. Just polling to see if is possible to do it the way I described. Thanks for the help
Old 01-31-2017, 09:08 AM   #12
Been doing it this way for 35+ years.
Days Camped: '17=30 '18=51 '19=58 '20=83
Old 01-31-2017, 09:22 AM   #13
Thank you
Old 01-31-2017, 10:05 AM   #14
I have a routine to make sure everything gets hooked up, latched, and plugged in and then I double check. I've seen plenty of banged up tailgates because people forget a step.
2015 Ram 3500 CC SRW SB 6.7 Cummins
2015 Sabre 36QBOK-7
Nights Camped, 2015: 23, 2016: 27, 2017: 29, 2018: 22, 2019: 29
mikeysotp is offline   Reply With Quote
Old 01-31-2017, 12:59 PM   #15
onetonford's Avatar
I drop tailgate and back up until I latch up still have about 4" to tailgate.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
Old 01-31-2017, 01:26 PM   #16
NMWildcat's Avatar
We have had many fifth wheels. Never had one that didn't have enough room to drop the tailgate while hitched. If you dont have enough room you might look at an extended pin box and have one less thing to worry about.
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 01-31-2017, 02:12 PM   #17
Thank you
Old 01-31-2017, 09:11 PM   #18
Thank you
Old 02-15-2017, 04:34 PM   #19
Like others, do the all the time. Just don't forget to lower tailgate BEFORE backing up and raising once connected.
High Desert is offline   Reply With Quote
Old 02-15-2017, 07:04 PM   #20
Thank you
fifth wheel, towing, wheel
