Old 11-15-2014, 07:34 AM   #1
furnace and roof blower running
camping in cold weather turned furnace on roof blower running all the time along with furnace is this normal thanks Dave
jollyhulk is offline   Reply With Quote
Old 11-15-2014, 07:39 AM   #2
Campfire Master
Make sure the fan setting on the thermostat is on AUTO. That should do it for ya.
John
AVid is offline   Reply With Quote
Old 11-15-2014, 07:41 AM   #3
thank u john
Old 11-15-2014, 08:49 AM   #4
I have the same problem but I can't find Auto. How do you get to it?
motodude79 is offline   Reply With Quote
Old 11-15-2014, 09:16 AM   #5
BombDoc's Avatar
Should be able to push the fan button on the thermostat and then + or - until you see AU. At least that is how it is on my thermostat.
John & April & "Scout"
2013 Sabre 32RCTS-6
Nights Camped 2013-(44) 2014-(59) 2015-(47)
2016-(32) 2017-(13) 2018-(20) 2019-0
BombDoc is offline   Reply With Quote
Old 11-15-2014, 09:17 AM   #6
thanks BombDoc
Old 11-15-2014, 09:27 AM   #7
BombDoc's Avatar
Originally Posted by jollyhulk View Post
thanks BombDoc
No problem. Did it work?
2013 Sabre 32RCTS-6
Old 11-15-2014, 09:28 AM   #8
Hunting right now will check it later
Old 11-15-2014, 09:33 AM   #9
Can't run the roof (AC) blower and the furnace at the same time on mine regardless of where the thermostat is set, On, Off, Auto, etc. When the switch is on Heat, it turns the AC blower off.
Old 11-15-2014, 10:23 AM   #10
How do you keep the moisture from collecting on the windows when using the furnace. Will cracking a window help?
Bloomington MN
Rockwood 2304S
TV is a 2014 F150 5.0 V8 with Equal-i-zer
jwuertz is offline   Reply With Quote
Old 11-15-2014, 10:27 AM   #11
We don't use the furnace, just the furnace blower. We use an EdenPure electric heater and the ceiling fan. Very little, if any moisture on the windows either here in NC or FL. Of course, we removed/replaced the day/nite shades with venetian blinds and get better circulation on the windows.
Old 11-15-2014, 04:25 PM   #12
Thanks We will have to get a an electric heater next season. We are all winterized and put in storage until spring.
Bloomington MN
Rockwood 2304S
Old 11-16-2014, 09:06 AM   #13
thanks to all for the suggestion and switching to auto it worked
Old 11-16-2014, 09:34 AM   #14
Witch Doctor's Avatar
Can you tell me what is the make of your thermostat, was it from the factory like a Coleman or did you change it out? Just wondering. Thanks in advance.
Coachmen M/H
Concord
2018 / 300 DSC
Witch Doctor is online now   Reply With Quote
Old 11-16-2014, 09:51 AM   #15
It is the factory just like bombdoc and John said switch to furnsce +- until u get auto switch to furnace workrd
Old 11-16-2014, 10:04 AM   #16
Yes I understand that, just wanted to know the name on the stat? The manufacturer in another words, like mine says Coleman on it. Some might say Dometic on them.
Coachmen M/H
Concord
2018 / 300 DSC
Old 11-16-2014, 10:07 AM   #17
sorry switch to blowe
Old 11-16-2014, 10:10 AM   #18
Dometic sorry camper came with it
Old 11-16-2014, 10:21 AM   #19
BombDoc's Avatar
It's Dometic Glen, you want a picture of it? I can go get one.
2013 Sabre 32RCTS-6
Old 11-16-2014, 10:29 AM   #20
BombDoc's Avatar
Dometic
Here you go Glen. I think it has something to do with factory test as several people have this issue when they bring their new unit home. The only fan options on the T-stat are Lo Hi and Au (Auto). Seems like they are left in the Hi or Lo setting when they leave the factory.
2013 Sabre 32RCTS-6
furnace, roo, roof
