Originally Posted by Iwritecode
The pic shows the valves in "dry camp" position.
Which, to my knowledge, has no bearing on whether the water heater is bypassed or not. The winterize position of those valves is for sucking antifreeze in through the connection on the left marked "Sanitize/Winterize". The valves on that panel adjust the flow of water through the water pump and city water connection, not through the water heater.
So, look at the back of the water heater, where the water heater bypass valves will be, and see if the water heater is still bypassed.
Notice page 12 of this manual:
https://www.bandbmolders.com/wp-cont...tilus-p2.5.pdf
"Important !!! Make sure you BY-PASS your water
heater if your unit requires it. Contact your RV
manufacturer for more information."
Therefore, my guess is that the water heater is still bypassed.
