Originally Posted by starnes550
So there is no adjustment on the pump/cylinder?
You can open/close the valve with a hex key just to reseat the valve, but that's about it. I've done that in the past and it helped for my system.
Find your system in these Master Manuals and they will usually have a pic of the valve(s) and instructions on operating manually to reseat.
https://support.lci1.com/master-manuals/
As for the cylinders, no adjustment for internal leakage. Some good hydraulic shops can rebuild them for cheaper than replacing them.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
