Old 04-22-2017, 09:13 PM   #1
New Wildcat owner.
Took the family from Vegas to California to look at a Wildcat 312BHX. Spend about 3 hours climbing all over it doing my own "PDI". Found one loose screw holding the soap dish in the bathroom and one bad fuse. Other than that everything checked out. So we pulled the trigger and bought it. Headed to a nearby RV park for the night. Hopefully no major issues show.
Mikeyt89148 is offline   Reply With Quote
Old 04-23-2017, 08:11 AM   #2
Welcome from Wisconsin and congrats on your Wildcat 312BHX.
Old 04-23-2017, 08:51 PM   #3
Second year with our 16 312 BHX. We like it a lot. If you need anything holler, I have been all over ours and have some good mods.
2016 Wildcat 312BHX
2015 Silverado 3500HD
sugarjohnson is offline   Reply With Quote
Old 04-23-2017, 09:06 PM   #4
SeaDog's Avatar
Sounds like you did a good PDI so you should have no surprises
Retired Navy
2016 Flagstaff 26 FKWS
Old 04-23-2017, 09:15 PM   #5
Blog: RVroadtripper.com
hbillsmith's Avatar
Nice to see another Wildone join the cause. Hope you have as much fun as we do. Don't forget to go to the top menu on this forum, select "Registry" and tell us all about your rig. While you're there you can learn all about the rest of us Wildones.
Maxxis 235/80/16E; AirBags w/AirLift1; mor/Ryde Rubber Pinbox; Andersen UltimateII Alum. 5erhitch on Reese Flipball w/Curt 4" offset; LCI Ground Control3; King Dishtailgater; Traveling with 10' Portabote;
hbillsmith is offline   Reply With Quote
Old 04-24-2017, 08:04 PM   #6
Congratulations. The Wildcats are nice rigs. Enjoy!
GypsiesAtHeart2016 is offline   Reply With Quote
Old 04-24-2017, 10:46 PM   #7
Would love to see what mods you have done? Thanks for the reply.
Old 04-24-2017, 10:50 PM   #8
Thanks for all the replies, I found two minor issue. First I was only getting Luke warm water while the hot water tap was open. Checked the bypass and someone left it open mixing the cold and hot. Second issue is that my outside speakers only play on the radio stations and I can't control the volume on them. Both sets of interior speakers work fine. I'm assuming there are a few loose wires behind the radio which I'll pull tomorrow.
cat, wildcat
