Originally Posted by Redneckrebel
Is it easier to just replace the check valve or try blowing air back thru it?
If it's stuck, you can NOT blow air "back" thru it, as the it's a one way thing, and you would be actually using air to close it in that direction...not open it.
You would have to blow air from inside the tank TOWARDS the check valve for it to open...like water pressure would do coming out of the tank.
