05-04-2022, 12:54 PM
Propane usage
2022 FR Wildcat 5th wheel.
Only camping used in the past with multiple propane tanks was in pop up. I used one tank until it stopped then closed valve and opened valve on other can. Then filled empty tank within next couple of days.
New trailer has two tanks. On one tank there is a gauge showing red and green. Plus a lever on top. From what I understood, I am supposed to open both tanks. Then I check the gauge each day or so. When needed the tanks will automatically switch and the gauge will turn red. Then I rotate the lever and refil the previously used tank.
Have I got this right or all confused?
05-04-2022, 02:35 PM
New here, old elsewhere
You got it!
2021 Coachmen Apex Ultra Lite 253RLS
2016 Silverado 1500 Crew Cab Z71 / 6spd / 3.73
05-04-2022, 03:04 PM
You got it.
Just remember, once the indicator turns red and you've flipped the lever, (turning the indicator back to green) DON'T FORGET to get the empty tank filled or the next time it turns red you will be totally out!
Many folks leave the lever alone until they fill the empty tank as a quick visual reminder one tank is empty.
The only caveat is 'some' regulators do not full flow in the auto-changeover position until the lever is flipped.
05-04-2022, 11:14 PM
Thanks for the help.
05-04-2022, 11:20 PM
One other caveat is that usually when the indicator is red, and the regulator is operating from the standby tank, there is a normally a lowered flow capacity. So, you might not have enough flow capacity to run the water heater, propane refrigerator, furnace, and stove/oven at the same time. It is probably about 99% chance not likely to be a real problem - but it does usually reduce flow capacity.
05-05-2022, 04:18 AM
Defender of America
This is something I wouldn't have thought of. Not disputing it ;but, how did you find this out? Must have been a cold day boondocking for all the appliances to be on propane. Do you have a flow meter on both tanks? How much does it reduce flow on the second tank? I assume there is a hierarchy of appliances for propane demand? Which one stops working first?
You've definitely peaked my interest in this science project!
Retired USAF
2021 Freedom Express 192RBS
2020 F150 STX 4X4 w/Coyote V8
Centerline TS WDH
05-05-2022, 04:43 AM
Here is a FAQ we keep on the propane cylinder automatic changeover
https://www.forestriverforums.com/fo...d.php?t=146655
2011 Flagstaff 831 RLBSS
05-05-2022, 05:43 AM
I just read the specification sheet for a propane regulator I was considering buying. I don't remember which one now. It had a lower BTU rating when it was in standby operation. Like I stated, there is 99% chance it will not have a noticeable affect.
05-05-2022, 08:07 AM
Great info. Thanks to this Forum I think I am starting to get a hang on a lot of areas I felt lost in. We close on the house on the 11th. By May 24th we will be full timers.
05-05-2022, 11:48 AM
are you sure it is auto changeover? Mine has the lever on top and it must be changed manually.
And why does it always run out at 3:00 AM in the winter?
05-05-2022, 01:00 PM
Haven't seen any manual switch over regulators in years. Even my first popup with dual tanks had an auto. Do yourself a favor and replace your manual one with an auto Not that expensive and easy to do.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
05-05-2022, 07:52 PM
Not sure why, but every manufacture I've seen in the last 15 years says it's reduced.
05-06-2022, 04:52 AM
Defender of America
I must not understand the term "standby". If the 2nd tank is waiting for the first tank to empty, there shouldn't be any flow from the second tank. When it switches over when the first tank is on empty; there's no flow from the first tank. Both are using all the same lines and no where do I see a "restricter".
As far as reading manufacturer data for the past 15 years (per second responders comment); please provide a specific link and I'll read it. Can't find any literature that states flow is "reduced" based on order of use. I have found that particular makes and models of equipment have different rates but not when you use 2 identical units on the same pipe system.
Again not calling anyone out. Just trying to learn the details. FYI I have a degree in Civil Engineering (not a plumber or pipe fitter) so I understand the concepts of flow and pressure. And I realize that no one needs to "school" me.
Retired USAF
Centerline TS WDH
05-06-2022, 07:43 AM
You are making this way too hard.
Don't think anybody said anything about a regulator drawing propane from both tanks simultaneously.
Some auto changeover regulators have different btu rates for the primary tank (the one the lever is pointed to) than for when using the secondary or standby tank (the one the lever is not pointing to). So when the primary tank is empty, the indicator is red, the regulator switches over to the secondary tank with a reduced flow. Full flow is returned when the lever is moved and pointed to the full tank, now making it the primary tank.
Here is one such regulator that indicated different btu rates (see product description details): https://www.camco.net/propane-double...aus-clam-59005
Other regulators do not seem to limit flow when the auto switch occurs. The one I purchased last time I replaced mine does not mention different btu rates.
05-06-2022, 11:56 AM
I'll provide one example, you can use google for others if you wish. You won't find this info in most of the sale sites, just the manufactures specs.
Propane Double-Stage Auto-Changeover Regulator - cCSAus,Clam
Item #: 59005
The Camco Propane Double-Stage Auto-Changeover Regulator is for RVs with dual propane tank hookups. It maintains a constant gas pressure and automatically changes from the empty tank to the full one. It allows for the removal of the empty cylinder for refill without interrupting the propane supply. The inlet is a 1/4" SAE inverted flare and the outlet is a 3/8" NPT female.
- Allows removal of empty cylinder for refill without interrupting propane supply
- Inlets are 1/4" SAE inverted flare and outlet is 3/8" NPT female pipe thread
- For RVs with dual propane tanks. Automatically switches from primary to reserve tank when primary is empty
- Primary cylinder 210,000 BTU/hr capacity; Reserve cylinder 130,000 BTU/hr
- Double stage design maintains constant gas pressure under changing demand and conditions
05-06-2022, 04:49 PM
Defender of America
Thanks NMWildcat & lwbfl
Thank you both for helping me out to understand the concepts. And yes, I appeared to be making this harder than it really was. I'm better now
Retired USAF
Centerline TS WDH
