We had an old Laredo fiver that had the television in a corner cabinet above a fireplace....we decided to upgrade the television and discovered that it was screwed into the cabinet from UNDERNEATH through the cabinet trim into the plastic cabinet of the television itself - this was original install also
Had to dismantle part of the fireplace trim to reach the screws - we also replaced the flimsy paneling shelf that was original factory install as well and put in a much sturdier plywood bottom - what a fiasco !
