light is switched, won't work
Had to fish a wire from the vent to above the cabinet above the peninsula where I cut a small hole in ceiling inside the cabinet, then found a hot feeding another light, patched the hole with foil tape for now, can't see it unless the cabinet is open and you're looking up from a chair. Had to cross over an AC duct and through a truss. Royal PITA, scraped up the arm on gang nails and staples but it works.
Word of warning, stay away from the knock off fans on Amazon that look like Fantastic Fans, they're not and they're a bit off and the trim for mine wasn't long enough, fortunately my local RV store, Benlo, had a trim piece that made it work.
