Old 01-17-2020, 12:06 PM   #1
Slide Gear rack maintenance
Should you use any silicone spray or slide lube on gear rack ? I see different issues on this.
MichaelW is offline   Reply With Quote
Old 01-17-2020, 01:32 PM   #2
Head Rambler
Ideally you want to use something that's dry during or drys after application, so dirt and grime doesn't stick to it.
While I love silicone spray for lots of things, I prefer 'Slideout Lube' for the slide mechanism because it is dry when applied and it's designed for that application.
Gotta go campin!
Old 01-17-2020, 02:04 PM   #3
D W
D W's Avatar
I use a solid film (dry) lubricant, Moly based. One application will last for six months. Superior protection against rust/corrosion. It's a dry lubricant so it doesn't collect debris.
You can find it at any auto parts store or Amazon under CRC or Loctite brand names.
'04 K3500 Silverado LS with LS3 Connect & Cruise- with Intimidator SSI PKG- Reprogrammed 4L80E
2016 Salem 27RKSS
D W is online now   Reply With Quote
maintenance, slide
