Old 11-24-2016, 08:39 PM   #1
TV Antenna Water Leak
When my antenna is down there is no problem . If I raise it and it starts to rain water drips from the crank inside . I've been on top looking at it and I have no idea how the water is getting down there only when it is up ? Any help would be appreciated....
govslug is offline   Reply With Quote
Old 11-24-2016, 08:58 PM   #2
Left Coast
Google that brand....might see a pic breakdown.....might just be an 'o' ring seal
Old 11-24-2016, 09:28 PM   #3
Flybob's Avatar
Sounds like a Wingard . Check where the coax goes into the roof mount. There is a boot on it and sometimes the boot will slide up the coax.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 11-25-2016, 07:13 AM   #4
RSchleder's Avatar
That's exactly what caused my antenna leak. The rubber boot was dislodged allowing water to enter where the coax cable goes into the roof. I filled the rubber boot with silicone adhesive, pushed it back into place, problem solved!
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 11-25-2016, 07:29 AM   #5
Inside the outer metal housing, on the shaft, are 2 O rings. If one of those gets torn or dislodged water will run down the assembly when raised, and when it does it drips off the handle......usually. Sometimes it will come out of the ceiling elsewhere but most of the time drips from the crank handle. When its leaking at the sealant or boot for the cable it usually drips from around the inner bezel or out of the ceiling elsewhere. Its a fairly common problem.
Do a search for "Winegard Sensar O ring replacement" and you'll get a ton of hits.
Mr Havercamp is offline   Reply With Quote
Old 11-26-2016, 10:42 AM   #6
Aging Junior Member
Jeff95814's Avatar
X2
2015 Wildcat Maxx 242RLX
2012 F250 6.7L Power Stroke
B&W Companion Slider
Jeff95814 is offline   Reply With Quote
antenna, leak, water, water leak
