Originally Posted by 5picker
I think that's what I said?? 4 & 6 similar and 10 & 12 similar.
All moot anyway as it is an Atwood.
yea its a Atwood lol
I found last night that they make a water heater that is the XT model = its 6 gallon but is equivalent to 9 gallons and keeps same size as the 6. Still 110v and Propane heat source. We want both heat options.
Info from online sellers site:
The Atwood 90073 Gas/Electric XT Water Heater - 6 Gallon gives you the equivalent of 9 gallons of hot water in the same smaller 6 gallon size. The XT will heat up cold water to a higher temperature, then mix it with additional cold water to provide you with 50% more hot water.
Mixing is made possible through the rear mixing valve that is already installed.
Install in the same size cut-out dimensions as standard 6 gallon Atwood models.
Winterizing bypass kit is already built in.
Aluminum tank is light weight and eliminates the need for an anode rod.
Dimensions: 16"W x 12 1/2"H x 19 1/2"D
Propane Output: 8000 BTU
Electric Output: 1400 watt
Weight empty: 23 lbs.
Mfr. 2 year limited warranty
We are probably gonna go this route and we don't have to cut for the increase height for the actual 10 gal water heater.
