Old 03-04-2017, 08:01 PM   #1
Water in light fixture
I've found water in the hall light fixture of my 2016 327RE. It's caused the LED bulb to to lose some its light. The roof was just inspected as part of my annual inspection. Any ideas? Dealer is two hours away.
2016 Wildcat 327RE2015 F350 DRW Diesel
Ebbs is offline   Reply With Quote
Old 03-04-2017, 08:09 PM   #2
crunchman12001's Avatar
Have YOU inspected the roof lately. If you are unable to get up there, do you know anyone you trust to inspect it for you?
That would be the first place I would check.
2015 F-250 FX4
Old 03-04-2017, 08:53 PM   #3
It just came back from the dealer where roof was inspected.
Old 03-04-2017, 09:00 PM   #4
While if there is water in a light fixture it has to come from the roof I would think. Thinking just like in a house water comes inside from the roof travels down the trusses leaks into the electrical box the light is attached to. As for the dealer inspection I would call them and see what they say. Two hours away tha causes problems. That is the reason I have decided not to get the fiver I was looking at and decided on a pull behind.
Gonefishing1 is offline   Reply With Quote
Old 03-04-2017, 09:21 PM   #5
Cyber Phrenologist
Radio's Avatar
We had a cracked shower skylight exterior bubble in our 5ver.
Once under the membrane the water traveled all sorts of places. So it may not be the "roof" that's leaking, but a skylight, vent, whatever.
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
Old 03-05-2017, 06:52 AM   #6
World Wide Wanderer
wahoonc's Avatar
If you paid the dealer for a roof inspection and you have water in the light fixture, they either DID NOT do what they were paid to do or did a very poor job of it. If you have the physical ability I would access the roof pronto and find out where the water is coming in, document it and then get a refund from the dealer. Water coming through the roof (or any other exterior point) on an RV is never a good thing.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is offline   Reply With Quote
Old 03-05-2017, 08:31 AM   #7
Aaron
X2
2015 F-250 FX4
Old 03-06-2017, 11:02 AM   #8
Wolverine 1945's Avatar
I would call the Dealer,,, tell them you have a roof leak,,, and you want them to send someone to your house,,, or send you your money back !!! Leak must be found pronto !!!
Wolverine 1945 is offline   Reply With Quote
Old 04-29-2017, 05:23 PM   #9
It's rained a number of times since first posting and there is no water or anything coming from that fixture again. The light fixture has stopped working though.
Old 04-30-2017, 06:42 AM   #10
Could be the bulbs,,, or a poor contact,,,
or maybe fixture needs to be replaced ???
Old 05-02-2017, 01:44 PM   #11
It's hardwired. $10 on Amazon.
light, water
