Old 11-25-2020, 11:53 PM   #1
Jukebox
Jukebox64's Avatar
X chocks
After purchasing a set of the X shocks to try and stabilize my trailer somewhat better than stock, I then realized my tires are too close together to use them. Has anyone else had this problem?
Jukebox64 is offline   Reply With Quote
Old 11-26-2020, 01:28 AM   #2
No. Ours were adjustable xchocks. It's possible that they don't make one that will fit your wheels. There are different styles and one of them might fit. Look for a description that tells you what size gap it will fit. Something like this https://smile.amazon.com/BAL-28010-X...6371761&sr=8-4
If you can't find one that fits, you might consider putting bottle jacks under the frame. It's time consuming though.
2015 Dynamax REV 24TB class C
Reverse_snowbird is online now   Reply With Quote
Old 11-26-2020, 01:46 AM   #3
They definitely make 2 sizes. Can you return them? My trailer only has about 3.5" between the tires at the narrowest point, and this one worked perfectly: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
The description says it works for gaps as little as 1 3/8"
-Qwkynuf
2003 F150 Supercab 4x4, tow pkg, 3.55 gears
2020 Flagstaff Micro Lite 21DS
Qwkynuf is offline   Reply With Quote
Old 11-26-2020, 09:45 AM   #4
My tires are very close and I actually have to turn the chocks with the supplied wrench to their tightest position (1-3/8") and then angle the wedges just right to get them in.
But... they fit and work very well.
For me, when camping, they are the first thing in and the last thing out.
Days Camped: '18=51 '19=58 '20=110 '21=15
Old 11-26-2020, 10:12 AM   #5
rsdata's Avatar
I use this style on my 14" tires with narrow spacing
https://www.amazon.com/Camco-Stabili...6403452&sr=8-2
"Freedom is never more than one generation away from extinction. " - Ronald Reagan
Too much of anything is bad, but too much good whiskey is barely enough.” – Mark Twain
2014 Shamrock 183
Old 11-26-2020, 10:23 AM   #6
acadianbob's Avatar
Clearly the solution is to move your axles!! Ha!
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
Old 11-26-2020, 10:33 AM   #7
Tapex's Avatar
As 5picker stated...
X2...same procedure for me to
2016 Coachmen Apex 250RLS Ultra Light
2019 Ram Big Horn Sport Longhorn
Tapex is offline   Reply With Quote
chocks
