Originally Posted by tndfraser
We just up-sized from our 20BHXL Wildwood to a 29VBUD Wildwood and went on our first week long outing. We really enjoyed the extra room and slide but we have one annoying problem we’ll need the dealer to fix. When running the air conditioner on high or low you can’t run the microwave for more then 1’30” or the main 30 amp circuit breaker will trip. The same thing happens when the hot water heater is run on electric cycle. Has anyone else experienced this issue?
Yes, on my flagstaff with a 15000 btu air conditioner, I usually cannot run the microwave along with the air conditioner in the hot summer without tripping the main.
It all comes down to total wattage/amps.....and your new A/C. microwave, etc may use more than your older RV did.
It's a matter of what you can have on, and thus other stuff must be turned off, to not go over the total amps.
Also the amount of 12 volt DC items you are using at any one time can have an affect on the converter 120 volt AC draw...which is added to the total of amps.
Turning off the hot water heaters electric element will save 12 amps.
These two links will help explain:
http://rvservices.koa.com/rvinformat...lectricity.asp
http://rvservices.koa.com/rvinformat...d-amp-draw.asp
