Old 07-27-2020, 07:53 PM   #1
Awning malfunction
I have a 2019 32BHI Wildwood triple slide TT series and I have a problem with my awnings. I am not able to extend my 2 awnings out. I have checked my breaker box and itís not tripped. I canít find the fuse location to see if thatís bad. I think I have power to the switches, a low Interstate battery outside and fresh batteries in the (I know itís not probably relevant). What do I need to be looking for or doing? The unit is no longer under warranty. Thanks!
Heleneh is offline   Reply With Quote
Old 07-27-2020, 08:02 PM   #2
rsdata's Avatar
there have been reports of the switch having corroded connections or a bad switch... you have to remove it from the panel to check this... others have found bad connections either at the motor end in the roller or along the length of wire from the trailer thru the arm to the roller.
Does the motor even click when the switch is pushed in either direction?
Are you plugged into shore power?
IS the battery disconnect switch pulled out?
"Freedom is never more than one generation away from extinction. " - Ronald Reagan
ďToo much of anything is bad, but too much good whiskey is barely enough.Ē Ė Mark Twain
2014 Shamrock 183
Old 07-27-2020, 08:14 PM   #3
Oaklevel's Avatar
The awnings are 12V so a good charged battery or on shore power is the first requirement. You say you checked the fuses,
Are you having anything happen ??
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 07-28-2020, 07:45 PM   #4
I am hooked up to shore.
I no longer hear clicking as I did in the past.
I donít know anything about a battery disconnect switch.
Old 07-28-2020, 07:48 PM   #5
Iím hooked up to shore, but my battery was low so I put it on a charger overnight.
The breakers were checked and nothing was tripped. The fuses I have no clue as to the layout and nothing in the brief manual I have designates anything.
Right now there is nothing happening with the awnings.
Old 07-28-2020, 08:18 PM   #6
Oaklevel's Avatar
I would find the fuses as the awning is not controlled through the breakers. Should be in the same main panel with the breakers.
Good Luck
1966 Mustang GT
1986 Mustang SVO
Old 07-29-2020, 04:16 PM   #7
I see the panel box with the fuses in them. Is there a manual to the location to the fuses?
Old 07-29-2020, 04:39 PM   #8
rracer5's Avatar
If you are hooked to shore power and your battery is still low, then you have another problem. 1) It sounds like the battery disconnect switch. Find it and turn it on. If it's off, your battery won't charge & 12v components won't work even if plugged in. 2) Check the breaker for the converter too. If it has tripped, the battery won't charge. 3) Also look for in-line resettable 12v circuit breakers. There is a little button on the side to reset them.
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 07-29-2020, 04:52 PM   #9
bikendan's Avatar
Each of the fuses should be identified on the panel door white sticker.
Old 07-29-2020, 05:05 PM   #10
Georgia Rally Coordinator
aceinspp's Avatar
Be nice if we new what manufacture of the awning was. Get more help and bette results. Later RJD
2020 Shasta Phoenix SPF 27RKSS
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
Days camped 2020 49
Old 07-29-2020, 05:10 PM   #11
aceinspp's Avatar
My awning malfunction due to a wire connection coming lose in side the awning roller. I have a Solaria awning. Later RJD
Days camped 2019 62
Days camped 2020 49
Old 07-29-2020, 11:26 PM   #12
Old 10-23-2020, 11:36 PM   #13
Do you have the wireless remote? If so, there is another set of fuses on the remote control PC board.
bradw661 is offline   Reply With Quote
Old 11-11-2020, 01:33 PM   #14
I need instructions on how to replace a dometic 9200 awning motor.
Vincent Rice is offline   Reply With Quote
Old 11-11-2020, 08:54 PM   #15
rracer5's Avatar
Sent you a PM.
2014 Sanibel 3250
awning
