Old 06-21-2023, 09:23 PM   #1
Battery Disconnect
Just purchased 2014 wildwood 252RKXL and looking for the battery disconnect.
EdNan is offline   Reply With Quote
Old 06-21-2023, 09:33 PM   #2
Might not have one. Removing the negative cable from the battery will disconnect it completely.
Welcome to the forum!
2015 Dynamax REV 24TB class C
Reverse_snowbird is online now   Reply With Quote
Old 06-21-2023, 10:34 PM   #3
bikendan's Avatar
Moved thread from the General Community Discussion section to the Wildwood sub-forum since the OP's questions are specific to a Wildwood model and not general questions.
I agree that it may not have a factory battery disconnect switch. Most stick and tin trailers don't have them from the factory.
Sent from my SM-G781U using Forest River Forums mobile app
Old 06-22-2023, 06:18 AM   #4
follow the battery cables...
if you got one, it should be the first thing you come to after the battery.
Mine is in the frame , off to the side and slightly under the battery
looks like a red flag
https://www.oreillyauto.com/shop/b/b...l/84414568e48a
Tarpon Springs FL
2022 Salem 24RLXL
Aussieguy is offline   Reply With Quote
Old 06-22-2023, 06:46 AM   #5
Oaklevel's Avatar
Welcome to the forum. Doubt very much that it came with one. If you do not have one it is easy enough to add.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Lillie Boxer Mix (RIP)
Old 06-28-2023, 12:26 PM   #6
Our 2016 253RLXL has a single battery and does not have a battery disconnect switch. If I am working with something on the DC system, I simply disconnect the battery negative cable at the battery. Otherwise, I see no need for a battery disconnect switch.
Now if I had two 12V batteries, I would add a battery selector switch which does provide an OFF position.
Bob
Bob K4TAX is offline   Reply With Quote
battery, battery disconnect
