Old 05-27-2013, 02:19 PM   #1
cplsms9300's Avatar
Black water tank wont empty
We tried to use the dump station when we left today but only a little bit of liquid came out. In the bathroom toilet ai can still see LOTS OF STUFF! Suggestions on what to do to get it all dumped out? Gonna be messy I know!
cplsms9300 is offline   Reply With Quote
Old 05-27-2013, 02:30 PM   #2
ridersfan's Avatar
Using too much paper? Is it normal household paper or the RV kind that dissolves easier?Going to have to hook up to a dump station and run lots and lots of water through the toilet. A hose going down the flusher would be more effective than just flushing it lots.
If you don't like my opinion, I'll give you a full refund on what you paid me for it.
ridersfan is offline   Reply With Quote
Old 05-27-2013, 02:30 PM   #3
TeresaInCAL
TeresaInCAL's Avatar
You're going to have to run water in there, either put a hose down the toilet, or use flush water from your tanks.
"Shhhh-stuff gets clogged up when either/or too much toilet paper is used, or you don't use enough flush water after each use.
Good luck!
Teresa
2013 f150 Ecoboost 4x4
2009 Gray Wolf, 22BH
TeresaInCAL is offline   Reply With Quote
Old 05-27-2013, 02:31 PM   #4
Denver, CO
garbonz's Avatar
Sound like a clog or a valve problem, neither very good. If you have access to a valtera external flusher. I would try that first to see if it is a clog that can be dislodged. Otherwise you have to access the valve and try to open it manually.
What unit do you hav eans does it have visible valves or are they hidden in the bowels (pun intended) of the sheathed under covering.
Need to collect whatever spillage in a tub or container and somehow get into a sewer.
Yeeeech.
2017 Fuse 23T
Old 05-27-2013, 02:42 PM   #5
Engineer of Crazy Train
ChooChooMan74's Avatar
X2 on the clog. I would try one of these first...
If that doesn't work, you're in a load of sh!t, no pun intended...
Possibly driving it around and dumping near home MAY dislodge it...MAY!
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183 (SOLD due to 2 years off work)
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -18
Come read my Camping Blogs
ChooChooMan74 is offline   Reply With Quote
Old 05-27-2013, 02:45 PM   #6
cplsms9300's Avatar
Garbonz... What is an external flusher? We have been using regular household tp but wont be anymore!!! I think the valve itself is eorking ok cause we did get some stuff to come out at the dump station. We will try the hose diwn the toilet. When I do this should the valve be opened or closed? I just dont want an overflow in the floor!! You know what I am saying? We are novice rvers and havent been doing this long at akl. It is all a learning process for sure! Thanks for everyones help!
Old 05-27-2013, 02:50 PM   #7
The big thing for TP is that it has to be septic safe. Here is a test from one of the people that I follow on YouTube.
Locomotive Engineer
Old 05-27-2013, 02:54 PM   #8
ridersfan's Avatar
Your dump valve should be a little of each... open and closed... and I don't mean half way open either. You want as much water in as you can get in, and then dump it.
Repeat
Repeat
Repeat
If it still has solids, then you will definitely need a power flush
Old 05-27-2013, 03:25 PM   #9
B47
Yeeeech.
There was a discussion about the Valtera flusher here yesterday - not all replies were good.
Do a search.
Old 05-27-2013, 03:33 PM   #10
Twisty's Avatar
There are also stories about a disc of tank wall being left in the tank after a hole saw is used at the factory.
FOR SALE 2014 BOSS 6.2L F350
2012 Surveyor SV264
NW Oregon
Twisty is offline   Reply With Quote
Old 05-27-2013, 04:02 PM   #11
bikendan's Avatar
could someone have used disposable/baby wipes or feminine products? those will definitely cause problems.
Equalizer WDH
Old 05-27-2013, 04:13 PM   #12
prof_fate's Avatar
angel soft TP is RV safe, availble everywhere and 'soft'.
Chris, Wills (16) Evie (13) & Toby our collie (6)
2011 Grey Wolf 28BH
2013 Chevy K1500 Crew w/ Reese StraitLine Dual Cam
Nights camped 2011: 11 2012: 18 2013: 12 2014: 12 2015: 13 2016: 56 2017: 8+
prof_fate is offline   Reply With Quote
Old 05-27-2013, 04:21 PM   #13
fonzie's Avatar
Get one of these and push water back into your tank removing clog. Then drain and repeat a few times.
Flush King - Valterra FK-01 - Sewer Flushing - Camping World
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 05-27-2013, 04:45 PM   #14
Black Water Tank wont empty
Try puting a 10-20 lb bag of ice down toilet and drive around to agitate it, use alot of water and anenzime cleaner to loosen the muck....try again to empty and repeat a couple of times.
Cmcsykes is offline   Reply With Quote
Old 05-27-2013, 05:04 PM   #15
kaldridge2004's Avatar
I have also heard that you can add ice (I think someone used 2 5lb bags) to help loosen anything that is 'stuck' on the walls of the tank. Then drive around and dump once the ice melts. This will help clean out the tanks.
2012 Rockwood 2109S MiniLite
kaldridge2004 is offline   Reply With Quote
Old 05-27-2013, 05:30 PM   #16
crunchman12001's Avatar
Bottom line is you put too much regular house paper down there. Next time use septic safe RV paper or what others have suggested. (it dissolves)
Also, make sure to use the RV toilet packet/chemicals before filling/using the tank next time. Full bowl of water with every paper flush.
You basically have what they call the brown pyramid. The paper built up under the trap and the liquid ran out.
You need to get the paper out. Your most sanitary option is to flush it out as described.
Plan B would be to get some trash picker uppers and pull it up out of the trap through the toilet if there is no liquid.
All else fails. Go to RV supply, buy a thing of tissue dissolver, some RID-X and a magic wand. Make sure the tank is full of liquid and add the chemicals. Let it sit for a few days. Find a campground or a place to dump at. Rinse and repeat.
Good luck
2015 F-250 FX4
Old 05-27-2013, 05:47 PM   #17
cplsms9300's Avatar
Good news everyone.... The great flush out worked. We ran a hose into the toilet and down into the tank. After a few minutes.... A great big gush and were back in business!! We did our best to get as much stuff out and I filled the tank up and ran it and the water was running clear! Thanks for all the suggestions and tips. We will be much more dilligent in ensuring that we use the right paper, pretreat and after treat this tank cause this was a mess!! Thanks again and happy rv'ing to everyone!
Old 05-27-2013, 05:52 PM   #18
Glad you got it. Enjoy the summer!
crunchman
2015 F-250 FX4
Old 05-27-2013, 06:42 PM   #19
bubbles's Avatar
Just something to add. I don't think it was mentioned but you should allow your black tank to accumulate a good amount of water before dumping. It's ok to dump after a short time if you add a lot of water before doing so. The more the better, I believe, is the credence.
Old 05-27-2013, 07:47 PM   #20
Denver, CO
garbonz's Avatar
Message #5 has the link, that device may unclog it also. And I like the drive around and try again, may be a cheap fix.
2017 Fuse 23T
