Originally Posted by TravelingDockerys
Will this hold two 50lb Ebikes?
I put a Aventon Pace 500 on my rack that is 50lbs and it worked real well. I also added a ratchet strap from the frame of the trailer to the bike rack frame and back to the trailer frame on opposite side. Since this bike frame sits so close to my trailer, I could not install another bike on the back side of bike rack without contact to the front of the trailer. I believe this unit states 80lbs with two bikes. With the strap easily 100lbs. If you remove both batteries, one on each bike, that's 20-25lbs less weight.
