Originally Posted by bobneal69
How do you get to this bracket?
On the Cherokee 38P, the bracket is a simple angle bracket on the top of the refrigerator, holding it to the back wall. Since it was a deep reach to try to remove the screw that went down into the top of the refrigerator, I removed the one from the wall.
I used two 1/4" drive extenders, a 1/4" screwdriver handle, and a 1/4" hex socket. I put a #2 Robertson bit (square drive, as all RV screws are) into the 1/4" hex socket. Using this scheme, I was able to remove the screw in the wall, and to replace it when finished. We left the drawer out and simply tuck goods into the cavity that remains.
In reading these forums, I have learned that some units use brackets on the floor instead. I seem to remember discussion about removing a trim piece, then either brackets or a wood batten that goes across in front of the casters.
Remember, they made it easy for themselves to assemble it; it should be easy for you to disassemble.
