Old 09-21-2021, 06:03 PM   #1
Draining my fresh water holding tank
How do I drain my fresh water holding tank on my 2019 wildwood 27rkss
David Howe is offline   Reply With Quote
Old 09-21-2021, 06:10 PM   #2
Normally by opening the drain valve. It's probably a small white plastic valve directly off the bottom of the tank, or on a side of the tank very near to the bottom. Probably looks something similar to this:
NavyLCDR is offline   Reply With Quote
Old 09-21-2021, 06:14 PM   #3
There is a drain valve attached to a plastic pipe but when I open no water comes out. The water tank is 1/3 full.
Old 09-21-2021, 06:20 PM   #4
If the plastic pipe is blue or red, it might be the plumbing low point drain. Either turn on the water pump, or connect to city water. Does pressurized water come out? If yes, that is a plumbing low point drain and not the fresh water tank drain. Also, are you sure the tank is actually 1/3 full with water in it, or just the light on erroneously?
Old 09-21-2021, 06:26 PM   #5
Someone else posted this picture, top picture, of their drain valve. It may be clogged. Might want to try to blow air into it with the valve open.
https://www.forestriverforums.com/fo...ml#post1128494
This is what they found wrong:
https://www.forestriverforums.com/fo...ml#post1130533
Old 09-22-2021, 04:58 AM   #6
I will give it a try. There is water in tank as when I turn off city water connection and turn on water in trailer the pump cuts in water comes from faucet.
Old 09-22-2021, 12:37 PM   #7
I have a Wildwood FSX. On my fresh water tank, I don't have a valve. Instead I have a cap on bottom of tank towards drivers side that needs to be removed. I unscrew it and the tank drains. There are 2 other caps just inside the lower edge of trailer and like @NavyLCDR mentions, these are the low point drains for both the hot and cold water lines.
2021 Wildwood FSX 190RT Toyhauler
2016 Chevrolet Silverado LT 1500 Crew Cab 5.3l 6L80 3.42 4x4
mikeyk101 is online now   Reply With Quote
Old 09-29-2021, 09:06 AM   #8
Wishyouwerehere's Avatar
our FSX has the same arrangement, simply screw off the white cap to drain.
Retired First Responder among others
Wishyouwerehere is offline   Reply With Quote
Old 09-29-2021, 09:10 AM   #9
Water tank drain
I had a kink in my drain hose from water tank. All good now . Thanks for your help.
drain, fresh water, tank, water
