Old 04-16-2020, 06:26 PM   #1
here to relax
Question Help please - built in outdoor griddle
Ok, this may be a stupid question but we are stumped....Is there a hookup for the built in outdoor griddle or do you have to use a separate propane bottle? We have looked and looked and can't find a hookup!! We have a 2020 Wildwood Travel Trailer. Please help!
Frank and Lorrie is offline   Reply With Quote
Old 04-16-2020, 06:31 PM   #2
Flybob's Avatar
Welcome to the forum.
Could be either. What does the propane port look like. I have seen ones that connect to a low pressure port on the side of the RV and ones that are simply a low cost model that is designed for the small 1lb high pressure bottles. If possible post a photo .
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 04-16-2020, 06:33 PM   #3
I have a quick connect propane connection at the rear of the trailer for the grill.
Wildwood 31KQBTS
Ford F250 6.7L Diesel
kellydthompson is offline   Reply With Quote
Old 04-16-2020, 06:38 PM   #4
Mr. Dan's Avatar
I have a Wildcat, not a Wildwood but my low pressure grill, etc., quick connect is under my steps... attached to the frame.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 = 26; booked = 42
Old 04-16-2020, 09:15 PM   #5
Mizterusa's Avatar
If its built in they must have some sort of valve or connection somewhere.... Id think!
Mizterusa is offline   Reply With Quote
Old 04-17-2020, 01:28 PM   #6
KEN9XL's Avatar
In my case as others have stated, the small low pressure propane outlet was on passengers side just in front of the rear bumper (same side as attached bumper grill). There is also switch on some that needs to be turned on prior to outlet.
Ken & Marie
2017 Heritage Glen 272RL - 34' 4" hitch to bumper (UVW 7294 lbs / hitch 845 lbs)
2016 GMC Sierra 1500 SLE (4wd w/tow pkg) 5.3 litre V8 engine, payload at 1726lbs with rear axle ratio at 3.42, & 9200 lb tow capacity
KEN9XL is offline   Reply With Quote
Old 04-17-2020, 11:25 PM   #7
HerveVR's Avatar
Look underneath your rig for a low prssure quick connect with a 1/4 turn valve.
Usually are Yellow coded.
2012 Lexington 265DS
HerveVR is offline   Reply With Quote
door
