Scorn,
Yes, the water heater is located on the opposite end of the electrical panel. The water pump is located under the kitchen counter at the sink. You need a #2 square bit tip to remove the inside panel (under the sink) to access the water pump. Mine did not come with the antifreeze attachment for the water pump, had to install it myself.
Bob
2013 Ford F250 SD 6.7L
2014 Wildwood Heritage Glen 282RK
Certified Rumble Strip Tester
