Old 06-29-2024, 06:00 PM   #1
Inside TV mounting location
Thought I would give everyone a heads up when trying to mount a TV inside a 2023 Forest River wildcat FSX 270 toy hauler....
That little sticker that says "TV mount" IS NOT the correct location to mount the TV! It's supposed to be, but apparently someone just threw the sticker in the middle of the area above the fireplace... Had to mount our TV about 2 in to the left of that sticker, and, unfortunately, plug a bunch of test holes!
Also, in case you didn't get manuals (like us), there's a little button with a green light on the antenna mount plate (on the ceiling above the TV mount location). Make sure you press the button so the green LED is lit, otherwise you won't get any TV signal.
Lockdown is offline   Reply With Quote
cat, location, mount, tv mount
