Old 09-30-2020, 05:48 PM   #1
Lighting seems dim
Fourth use of our new 2020 Forest River Wildwood Heritage Glen LTZ 286RL and first in 2 months. Our site has 50 amp service and our Hughes Autoformer surge protector shows all green. Interior lights seem dim. suggestions?
Socrbent
West Central Ohio
socrbent is offline   Reply With Quote
Old 09-30-2020, 05:52 PM   #2
Is the breaker turned on to your converter? I'm assuming that you have seen them brighter in the previous 3 uses. Since the lights work off of 12 volts DC, it's going to be a battery issue of some sort. Can you put a meter on your battery and measure the voltage?
2012 Cedar Creek 36CKTS Touring Edition
2015 Ford F-350 CC DRW Lariat
Joe_GA is online now   Reply With Quote
Old 09-30-2020, 06:05 PM   #3
more on lighting
Yes dimmer than before. We have 2 batteries. They were low yesterday evening. I turned off disconnect overnight. Ran truck for an hour prior to leaving today for an about 3 hr. trip to current location. Wall indicator shows batteries low. Shouldn't shore power be charging batteries and provide full 12 v to rv?
Socrbent
West Central Ohio
Old 09-30-2020, 06:53 PM   #4
Head Rambler
Can you answer Joe's first question? Are you sure the converter breaker is on?
If the converter is on and and charging it will power the 12 volt appliances and charge the batteries.
Gotta go campin!
Old 09-30-2020, 07:23 PM   #5
Thanks Bama and Joe. You were right, it was a breaker tripped for converter. Problem solved as long as breaker doesn't trip again soon. I was focused on my inverter that was showing an error.
Socrbent
West Central Ohio
Old 09-30-2020, 07:37 PM   #6
Glad that took care of it!
Old 10-01-2020, 08:53 AM   #7
Head Rambler
Thanks for coming back and letting us know what it was.
I'm glad it was something simple.
Gotta go campin!
light
