Old 08-19-2022, 06:48 AM   #1
Location of 2018 Wildwood water pump
I am trying to find the location of the water pump of my 2018 Wildwood RV. Could anyone help me out?
Cachapa2020 is offline   Reply With Quote
Old 08-19-2022, 12:22 PM   #2
bikendan's Avatar
You need to post what model number your RV is. Water pump locations vary by brand or model number.
Moved thread to the Wildwood sub-forum since the OP is asking for model-specific information.
Old 08-19-2022, 12:53 PM   #3
Is it possible to turn it on and listen for the sound. That is how I found mine in the entertainment cabinet. Running the pump dry for a little bit will not hurt it.
KKonyha is offline   Reply With Quote
Old 08-19-2022, 01:59 PM   #4
Try looking for a panel that's attached by screws.
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 08-19-2022, 07:06 PM   #5
Hi I hope this helps
VIN Number: d4X4TWDC26JA262949
2018 FOREST RIVER Wildwood Towables
Old 08-19-2022, 07:21 PM   #6
bikendan's Avatar
There should be a model number decal near the door.
Since this forum has no affiliation with Forest River Incorporated, we have no way to look up the VIN.
Wildwood probably made more than 50 different model numbers in 2018.
Old 08-19-2022, 07:34 PM   #7
Oaklevel's Avatar
As has been mentioned we need your model number. Ours is a 2017 Wildwood 4092 BFL. Ours is under the bathroom sink yours coud be under the kitchen cabinet or elsewhere.
I assue that you are having an issue ???
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 08-19-2022, 08:01 PM   #8
bikendan's Avatar
Your profile says you are in Aguadilla, Puerto Rico. Is this where your Wildwood trailer is located? Is it a former FEMA trailer?
Old 08-23-2022, 10:02 AM   #9
Typically it will be placed inside a cabinet or seat frame (non-slideout models only), usually on the same side as the freshwater/city water tank fill inlets. Most likely, it will be inside a cabinet frame that is within a couple of feet of those inlet valves. You will probably have to remove a few screws to access the pump.
bobkeown is offline   Reply With Quote
Old 08-27-2022, 02:40 PM   #10
I have a 2020 Wildwood and mine was behind a small non-removable panel (that I made removable), which was next to a larger removable panel. The pump was located right near where the water fill ports were.
I used a putty knife to get between the cabinet frame and the very thin plywood that makes up the panel. Before doing so I used a sharpie to mark around the frame where I was removing the panel to use them as trim marks. After removing the panel and the left behind staples, I used small strips of 1/2 ply as backer strips for the now removable panel to attach to. I trimmed the panel to size and attached it to the backer strips with a couple of screws.
I’ve done this with all of the non-removable panels in my trailer and found a couple of more square feet of storage space along the way.
ó
DS2 USN 73-79
Forest River 2020 Wildwood 171RBXL
Highinthemountains is offline   Reply With Quote
cat, location, pump, water, water pump, wildwood
