Old 05-26-2022, 10:12 AM   #1
Mystery Valve
In Water hook up bay on a 2020 Forest River Wildwood Heritage Glen LTZ 286RL 5'er there is a valve on pex line unmarked. What is it for? It is not the heater bypass which is clearly marked.
Socrbent
West Central Ohio
socrbent is offline   Reply With Quote
Old 05-26-2022, 10:26 AM   #2
Can you post pictures of what valve you are talking about?
something semi close and then a wide view or 2 to show where it is.
Phreak480 is offline   Reply With Quote
Old 05-26-2022, 11:00 AM   #3
Mr. Dan's Avatar
It’s a valve that can be opened and closed? Antifreeze input hose?
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 =108/'21 = 115/'22 = 68; Booked for 2022 = 41
Old 05-26-2022, 11:04 AM   #4
bikendan's Avatar
Pics are often more helpful than descriptions.
Sent from my SM-G781U using Forest River Forums mobile app
Old 05-26-2022, 11:21 AM   #5
It is the white valve on the white pex. When I move the other white pex (antifreeze inlet) it seems connected. If it is for the the antifreeze inlet then for normal operation it should be closed - Right?
Socrbent
West Central Ohio
Old 05-26-2022, 11:27 AM   #6
Looks like it is an inlet for antifreeze.
Old 05-26-2022, 12:14 PM   #7
Mystery valve
Like already mentioned, the suction for anti freeze. I bet if you pull on one end of the pex , it will come out revealing the end that goes in the jug.
2021 Ram 3500 Dually , 6.7 Cummins, 2021 CC 385TH , 2019 HD Heritage Softail
RCerf is offline   Reply With Quote
Old 05-26-2022, 01:16 PM   #8
The white pex just below the city water connection has the end for sucking in antifreeze just out of lower edge of the picture. When I pull or wiggle that pex it moves the pex connected on left side of valve. So the valve seems to be for the antifreeze inlet.
Question - when connected to city water or to fresh water holding tank via pump this white valve should be closed and the red valve for hot water tank bypass should be in normal position (not bypass)?
Socrbent
West Central Ohio
Old 05-26-2022, 04:37 PM   #9
Correct.
2015 Chevy 2500HD 6.0 4x4 CC SB
2021 Salem Heritage Glen 290RL
Andersen Ultimate
1200W solar > 412 Ah LiFePO4 > Victron MultiPlus II > Cerbo GX
corn18 is offline   Reply With Quote
Old 05-26-2022, 04:41 PM   #10
Thanks for the confirmation.
Socrbent
West Central Ohio
valve
