Old 08-12-2022, 11:05 AM   #1
need to replace tub and tires
Where is a good place to go to find a tub replacement for my 2002 Wildwood? I have seen them on line but the drain holes are all in front or in the back of the tub and I need the drain hole on the side.
Our trailer is a heavy trailer. Which tires should we be looking for? Iíve heard trailer tires or light truck tires. Just want something that can support the weight of the trailer.
Thanks!
todohert is offline   Reply With Quote
Old 08-12-2022, 11:46 AM   #2
You could call Forest River Parts department and see if they have it or can refer you to the manufacturer.
What kind of tires are on the rig right now? A tire shop should be able to tell you what you need. You'll need the loaded weight of the trailer and the speed you tend to travel at. Many tires, for example, are speed rated at 65 mph and if you travel at 70, that won't do. A higher speed and load rating is recommended.
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 08-13-2022, 08:45 AM   #3
There are enough tire threads here to keep you reading for days. Look at the weight spec/tire sticker on the front left of your trailer. Get tires that meet or exceed the requirements. Good ST tires include Goodyear Endurance, Sailun, and some Carlisle. Generally, LT tires can't carry your axle weights.
--2005 F350 Superduty Crewcab, 6.0, 4wd, short bed, 3.73 gears;
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
phillyg is offline   Reply With Quote
tire, tires
