02-25-2022, 07:34 PM
New camper, lots of questions
Hey everyone, we just bought a 2020 wildwood xlite 273qbxl and love it so far. I am someone who like to do any preventive maintenance on my toys. Can you tell me if I need to do anything with the slide to keep it working properly? This is our first camper with a slide. Does this model come with a black tank flush? If so where is it located? My last travel trailer had a gas/electric refrigerator, this one is only electric. How do you travel with it full of food and keep it cold? I am taking it to ,y local trailer shop to check the brakes, bearings and tires to make sure it is good to go for this season. Is there anything else you can tell me about this model? Thanks again.
02-25-2022, 08:33 PM
This forum will certainly help you with you new toy, however youtube is an awesome source of information. Good luck and have fun.
2022 Cherokee Wolf Pup 18TO
2022 Dodge Ram 2500 6.4l Bighorn
02-25-2022, 08:36 PM
Multi-Slacker
Welcome from SoCal!
Slides need lubrication. Consider a topper to keep debris off and out. There is a Wildwood specific forum that will be of more help.
Safe Travels
02-25-2022, 09:04 PM
Originally Posted by CurtPutnam
Welcome from SoCal!
This thread is in the Wildwood sub-forum.
02-25-2022, 09:28 PM
Elecric refridgerator are the subject of much discussion. Make sure the fridge is cold (run overnight) before placing food in it. Assuming your distination has AC, you should be fine until you get there. If it a long trip to your destination, you may need some frozen jugs to get you there.
Check on your tires and confirm that they are from a reputable source (not Castlerock)
2021 2205S Rockwood Minilite
2019 F 150 Lariat 3.5 Eco Fx4 Max Tow
Equal-i-zer WDH, 1809 lb payload
02-25-2022, 11:06 PM
Pseudonym
If you're using a 7-pin umbilical between your trailer and tow vehicle, the 12V supply will run the fridge. Make sure your battery is charged before you travel.
2021 Shasta 18FQ
2023 Ram 1500 4X4 Lone Star Crew Cab 5.7L HEMI eTorque
Attachment 251949
02-27-2022, 09:35 AM
NOT true if he has a 120 Volt Reefer.
If he does have a 120 Volt Reefer he could install an inverter to power it while traveling though.
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
02-27-2022, 02:45 PM
As indicated, your fridge either needs an inverter (dc to ac conversion) or needs to be plugged into a 120v source at campsite (either at pole or generator). If you get an inverter, you need to make sure it can output the wattage necessary for your fridge and know how to connect it to your batteries.
I lube my slide rails with a dry lubricate every season and make sure to run it out and in every once in a while. I also treat the slide seals with a UV protectant every few months.
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
02-27-2022, 02:56 PM
Is the refrigerator a residential refrigerator (120 volts ac) or a camper refrigerator (12 volt dc)? Is 120 volt and model year 2020 it will have an inverter already installed.
In either case run the refrigerator while lugged into shore power for several hours before you leave in order to cool it down. Make sure your batteries are fully charged before you leave. If you do both these things you should be able to drive all day and keep the refrigerator running. Then plug back into shore power when you arrive at your destination. If shore power is not available then things get a bit more tricky.
For what it is worth we travel all day with a residential refrigerator and two group 27 batteries keep it running! We plug into shore power at night.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
02-27-2022, 04:06 PM
Did anyone read what he said gas / electric frig run the frig on gas while traveling .
02-27-2022, 04:08 PM
Thanks for all of the replies. Next question is when I am plugged in at home and storing my camper, is there a way to turn my refrigerator off? It seems to be running while I am plugged in and I would like to turn it off in between camp trips.
02-27-2022, 04:20 PM
The OP stated that their PREVIOUS trailer had a gas/electric fridge. Their new trailer has electric only but didn't clarify if it's a 110v AC only fridge or a 12v only fridge.
02-27-2022, 04:21 PM
Until you clarify what type of electric fridge or post make and model number of fridge, not much can be said.
02-27-2022, 08:11 PM
So you have confirmed that there is no on/off switch on the refrigerator itself?
If 120 volt turn the circuit breaker off. If 12 volt pull the fuse. There have been quite a few posts concerning 12 volt refrigerators and how to turn them off.
Third option, which many promote, is to put the extra beer in it and let it run.
02-27-2022, 09:00 PM
You need to post the make and model to get an answer as to whether you can turn it off when plugged in......
I vote for option #3.
2015 Dynamax REV 24TB class C
03-01-2022, 08:04 AM
Pseudonym
@jobofly tell us the damn make and model of your fridge so we can actually help
2021 Shasta 18FQ
Attachment 251949
03-03-2022, 04:48 PM
Sorry for the delay, i dropped the camper off to have the brakes, bearings and tires checked and just got it back today. The model is
Ever chill model wd-282fwdc
03-03-2022, 05:29 PM
Awesome thank you!
03-03-2022, 05:32 PM
That fridge is 12v ONLY. So it runs straight off the battery.
Now you need to research the challenges of a 12v only fridge.
Most add at least 200w of solar and upgrade the batteries, to 6v golf cart batteries, AGM batteries or LiPo batteries.
