Old 02-15-2020, 04:40 PM   #1
New rv
We are looking at buying our first rv and not sure what would be a good quality starter. 2017 wildwood heritage glen hyperlite 29bhhl for 20k.
We need help!!!!! Are these good quality trailers? Any complaints or warnings.
MT2020 is offline   Reply With Quote
Old 02-15-2020, 05:42 PM   #2
Cabinfever97's Avatar
We have a Hemisphere. I believe Heritage Glen and Hemisphere come out of the same building. So far our Hemisphere has been good. All units, no matter cost, can have issues from small to major. I'm sure you will get more in put from the forum that will help you.
Cabinfever97 is offline   Reply With Quote
Old 02-17-2020, 04:42 PM   #3
ive been happy with my heritage glen 5th wheel. I feel the brand is a good value. there are less expensive units built cheaper and more expensive units built better.
Kimber45 is offline   Reply With Quote
Old 02-17-2020, 05:38 PM   #4
Thanks. Do you think the trailer is as good of quality as the 5th wheel?
Old 02-17-2020, 06:54 PM   #5
Is it normal to have the plywood under the popout to be wet or is that a problem sign?
Old 02-17-2020, 07:29 PM   #6
bikendan's Avatar
Are you asking about under the slideout?
If so, is the slideout in or out?
Equalizer WDH
Old 02-17-2020, 07:51 PM   #7
the 5th wheels and tt are built on the same line with the same materials. im not sure what you mean by pop out. no plywood should ever be wet
Old 02-17-2020, 07:57 PM   #8
Yes under the slide out. We are looking at one to buy. The slide out is out.
Old 02-17-2020, 07:58 PM   #9
Would this be something that we should be weary of buying? It seems solid still but the edge is spongy.
Old 02-17-2020, 10:20 PM   #10
bikendan's Avatar
I wouldn't.
Equalizer WDH
Old 03-02-2020, 10:27 PM   #11
James Ww's Avatar
If something is wet when your looking at it, I would not buy it...if I did I would be hyper vigilant, because you have a problem somewhere. Also, feel the wood in other places and see if there are other soft spots.
If you got in a 2 year old truck and found water on the floor...would you buy it?
James Ww is offline   Reply With Quote
Old 03-05-2020, 10:31 AM   #12
If its wet and spongy already I would move on. That is too new of unit for an issue like that. The slide out might just need an adjustment to stop the leak but the wood could already be compromised. Where are you located? I have a 2017 Wildwood Heritage Glen 300BH and we are upgrading to a fifth wheel this spring!
cuttymcgavin is offline   Reply With Quote
Old 03-05-2020, 10:43 AM   #13
SPONGY? Run in the other direction. Spongy indicates that something has been leaking for some time. You don't know where that leak is coming from.
Mold could be growing there too.
Replacing the floor under a slide is extremely expensive. Actually, replacing any floor is expensive.
2015 Dynamax REV 24TB class C
Reverse_snowbird is online now   Reply With Quote
Old 03-05-2020, 11:00 AM   #14
NMWildcat's Avatar
Any spot of spongy/damp floor, wall, or roof on any potential RV purchase,, is an automatic pass for me.
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
