Old 02-08-2023, 01:18 PM   #1
Plumbing Question
Kitchen sink drain began leaking from the coupler that connects sink line to p-trap. Thought that simply tightening the coupler back up would do it. No such luck. Removed p-trap, checked all seals, reinstalled and now I cannot get the coupler to secure p-trap back to sink drain line without p-trap easily sliding right back off.
I've attached visual aids. Do I have the order of seals correct? Should the tapered end of the seal (at top in pic) be pointing down into coupler or up toward sink bowl?
ID:	283745   Click image for larger version
2017 Wildwood T195RB
2020 Ram 1500 Hemi Longhorn
Donovan W is offline   Reply With Quote
Old 02-08-2023, 02:39 PM   #2
The tapered seal should point down into the bevel of the trap. When the nut is tightened it will push the seal down and the bevel of the trap will push it in to close around the sink pipe.
2019 Palomino Solaire 147X
2013 Ford F150
TacomaJoe is offline   Reply With Quote
Old 02-08-2023, 02:51 PM   #3
cmulvey's Avatar
X2
Christian M
2021 Forest River Forester 3011DS
cmulvey is offline   Reply With Quote
Old 02-08-2023, 05:13 PM   #4
So I've got tapered end down into trap, flat washer on top of tapered one, and coupler on top of that. When I tighten up coupler, however, it does nothing to hold trap tight against straight length from sink bowl The slightest downward pressure on the trap will separate the two sections. Do I have something out of order?
Old 02-08-2023, 05:57 PM   #5
put the seals and the NUT on the pipe first...
push everything UP higher than normal (out of the way)
then put the rest of the P trap in place
Loosen the other side if things don't quite line up...
get everything in place so they all line up nicely.
start hand tightening on the drain side of the P
then push the seals and NUT down onto the P and tighten
Usually only need to hand tighten to seal (use towel/gloves for better grip)
but if you must use any wrench etc only NIP it together only a tiny little bit
Tarpon Springs FL
2022 Salem 24RLXL
Aussieguy is offline   Reply With Quote
Old 02-08-2023, 06:10 PM   #6
Flat washer .... are you sure it is suppose to go there....
Is there one on the shorter curved end?
Make sure the part of the P trap that connects to sink goes about 3/4 - 1" over the sink tube
If it doesn't loosen ALL the fittings and slide things around so it fits better
You can purchase longer tubes OR extensions if it needs one
Tarpon Springs FL
2022 Salem 24RLXL
Old 02-08-2023, 06:25 PM   #7
SUCCESS!!! Getting everything in place on the long drain stem was the key. Flat washer needed a little coaxing to get around the pipe but it went. NO MO DRIP!
Thanks so much.
plumbing, question
