Old 10-23-2019, 11:37 AM   #1
mike830's Avatar
replacing fridge
have a wildwood x lite 201bhxl. the fridge only runs on electric. when no hook up runs on 12v. kills the battery in about 1 1/2 days. wondering if it's worth replacing it with a propane/electric one. has anyone done that?
mike830 is offline   Reply With Quote
Old 10-24-2019, 08:39 AM   #2
SeaDog's Avatar
In terms of worth it or not that is sort of a call you have to make. with that said before you figure the total cost of replacing you will need to ensure that the rig has propane available which if not would add to the cost. Might be less hassle and cost effective to invest in a small generator to satisfy your dry camping needs.
Retired Navy
2016 Flagstaff 26 FKWS
Old 10-24-2019, 08:50 AM   #3
mike830's Avatar
thanks SeaDog, you think a 2000w generator would be enough to charge a 12v 100ah battery?
Old 10-24-2019, 09:19 AM   #4
SeaDog's Avatar
That would easily run your converter and charge your battery and allow you to run most things in your rig.
Retired Navy
Old 10-24-2019, 09:25 AM   #5
mike830's Avatar
thanks. I will look into getting one
Old 10-24-2019, 10:04 AM   #6
SlowrideHD's Avatar
If you have the room to put one, or can modify space for one, it would really help to add another battery in parallel with the one you have. A 100 Amp, 12v battery only has about 50 amps, or 600 watts available until battery capacity drops to 50%, about 12.1 volts. Utilizing the battery past this point will shorten its like drastically. That's. not many hours of use.
An even better solution is to use two 6 volt golf cart batteries like the Trojan T-105, hooked in series to give you 12 volts. This would give you about 1400 watts of energy use before requiring a recharge.
Note that a lead acid battery that is pulled down to 12.1 volts or less will require a lengthy charge to get back to full capacity. You may get to 90% in a couple hours but to get to 100% may take an all day charge. A 2000 watt quiet inverter generator would add immensely to a comfortable camping experience.
2016 F350 CC Dually Powerstroke 4x4
2014 Cedar Creek 34RLSA w/Level Up
2007 HD Ultra Classic 103
SlowrideHD is online now   Reply With Quote
Old 10-24-2019, 10:15 AM   #7
TowPro's Avatar
looking at rv trader, your rig appears to already have a Propane refrigerator in it.
I don't think its a new 12v compressor refrigerator is it?
what kind of battery do you have?
24 series is around 75amp hours
27 series is around 90 amp hours
(your not supposed to drain a battery past 50%)
but here is your times below
if you leave the rig sit unplugged I bet you have 1 amp draw on the battery still with your CO and Propane detectors even with refreg off.
battery size - 50% dead, - total Dead
24 series - 37.5 hours- 75 hours
27 series - 45 hours - 90 hours
add 3 amps for Propane refreg to run (plus 1 amp for CO/Propane detector load = 4 amp)
24 series - 9.3 hours- 18.75 hours
27 series - 11.25 hours - 22.5 hours
This don't include any lights or water pump load.
Maybe the answer is to add more battery?
or some solar?
(your load would require about 200w of solar)
or just run that generator to charge the batteries you got.
2019 Forest River Forester MBS 2401R
TowPro is offline   Reply With Quote
Old 10-24-2019, 10:33 AM   #8
mike830's Avatar
the fridge is definitely electric only. I do plan on getting another battery next year....and a generator. the battery is 27 series. I will connect the two together. with that and a generator I hope to be ok.
Old 10-24-2019, 10:43 AM   #9
or some solar?
Forest river brochure here:
https://library.rvusa.com/brochure/2...d%20X-Lite.pdf
States 12v refrigerator, must be one of the new compressorized refers.
nayther is offline   Reply With Quote
Old 10-24-2019, 11:48 AM   #10
TowPro's Avatar
sounds like the everchill refreg.
"once cooled, this runs 3 amp to keep cold"
and In same link it says it needs 11 amps to work.
Old 10-24-2019, 01:39 PM   #11
mike830's Avatar
it is the everchill
Old 10-24-2019, 02:03 PM   #12
bikendan's Avatar
You may not fit two group 27 batteries without some modifications. The battery framework on the A-frame, is usually sized for two group 24/6v GC2 batteries.
I suggest that you get two 6v golf cart batteries and a 2000w inverter generator. Unless you want to run the a/c, then you'll need a bigger inverter generator or install a Micro Air Easy Start unit.
Equalizer WDH
Old 10-24-2019, 02:10 PM   #13
mike830's Avatar
are the 6v batteries better than the 2 12 v?
Old 10-24-2019, 02:22 PM   #14
bikendan's Avatar
Your 12v batteries are most likely the cheapest 12v dual purpose marine batteries the dealer could find. These are NOT true deep cycle batteries, like 6v golf cart batteries are.
I'll bet your battery has a Cold Cranking Amps rating. The rating is for starting engines, which your trailer doesn't have.
6v golf cart batteries are designed better for the type of usage a RV needs.
Equalizer WDH
Old 10-24-2019, 02:46 PM   #15
mike830's Avatar
it did come with regular batteries. I bought one 27 series true deep cycle, 12v 100 ah, and was going to buy another next yesr. would 2 6v be better than 2 12v?
Old 10-24-2019, 02:59 PM   #16
bikendan's Avatar
Are you sure that group 27 battery is a TRUE deep cycle? True deep cycle 12v batteries aren't common.
Can you post a pic of it? Or brand and model number.
Equalizer WDH
Old 10-24-2019, 03:11 PM   #17
mike830's Avatar
I will post a pic tonight. I know it is one of those agm batteries.
Old 10-24-2019, 04:32 PM   #18
bikendan's Avatar
Well, that's different. I assumed you were talking about lead acid batteries, since you didn't mention AGM.
All I know about AGM is that they are better than lead acid but they're too expensive for me.
Equalizer WDH
Old 10-24-2019, 05:12 PM   #19
TowPro's Avatar
typically a 6v golf cart battery is a better deep cycle than the multi purpose 12v marines ones.
Most 27 series 12v batteries are rated at 90amp hour.
If you put Two 12v batteries together (parallel) you get 12V @ 180ah
Most golf card 6v batteries are rated at around 230amp hour
If you put two 6v batteries together (series) you get 12V @ 230 ah.
be careful, lots of golf cart batteries are now 8v.
golf cart batteries are taller.
If you guy AGM you don't a have to add water.
Old 10-24-2019, 05:22 PM   #20
mike830's Avatar
here's the battery I have and was planning on getting the same one in the spring. Maybe I'll look into the 6v ones. will they fit into the same box?Click image for larger version
fridge
