Rewire to use factory installed solar port after a battery disconnect is installed.
Our 2018 Wildwood came equipped with the very expensive Furron Solar Prep including prep and TT mounted female jack (MSRP $225.00).
We located the correct OEM connector that allowed ANY solar panel to connect to the TT mounted solar jack. This avoided the expensive Furron solar panels. Everything good.
The solar connection worked no issues UNTIL I installed a battery disconnect on the battery. This, of course, removes battery power to the TT and stops battery drain with the TT is in storage. NOW THE ISSUE.
The factory made no provisions for the solar powering port to be connected to the battery IF A BATTERY DISCONNECT WAS INSTALLED. This made the expense solar powering port useless, as it is currently wired.
Has anyone rewire the solar port to provide a "charging path" to the battery when the battery disconnect is disengaged ?
I have climbed under the TT trying to trace the solar port to the battery via a couple of frame mounted junction boxes, but I can not see the entire wiring path.
Thanks in advance.
Florida Traveler
Pembroke Pines, FL
2018 Wildwood x-lite 230BHXL
2021 Ford F-150, 5.0L Super Crew
Retired, Electrical Engineer
USN Vietnam Vet Brown Water Navy PBR 534 1968 - 1970
