An FYI blind adjustment reveal. My grandson (4yer old) pulled one of our blinds all the way down and we couldn't get it to go back up. 2018 Wildwood RKSS 27ft. Blind picture attached. To remove the valance pry out the clip (which is the round centered piece shown) from both sides of the blind. You can but don't need to remove the nearby screw(square bit required if you do) to get the valence off. This will reveal a phillips head adjuster that you simply can turn to adjust. Real easy may just look formidable to some.
