Originally Posted by Jerr
Hi .....
Late last fall we just picked up a barely used 2021 Heritage Glen 25RBHL. It has many options but didn't come with the factory-installed rooftop solar panel. However, I understand all the connections are there.
I've been searching all over for pictures/specs of the connections and brackets with no luck.
Can somebody share pics or know what size (dimension) solar panel this trailer is set up for?
I'm considering a Renogy system and want to make sure I buy the right system.
I can't climb up to check as the trailer is in storage 1.5 hours away.
Thanks!
My question is, how do you understand the connections are there? I have the sister unit (salem) in a 2020 model and while there is a "port" on the side of the trailer for solar power, I've never seen anything else and I have looked on top of the trailer.
Now maybe its hidden inside of something or I missed it. I have seen models like mine with solar panels attached to the roof, but I would be surprised that they put all the wiring in there and no panel. But maybe they do that sometimes.
I just wouldn't want you to buy something and not be able to return it.
Good luck with it though!!
