08-31-2020, 10:53 AM
Running lights
I've seen people camping with running lights on. I have 2003 Wildwood anyone know how it's done? I tried the trick with fuse in 3&4 pin doesn't work. Any ideas?
08-31-2020, 02:09 PM
PhD, Common Sense
3 & 4 are the correct pins—the two immediately below the tab that fits into the notch.
Is your fuse good? Did you try another fuse?
08-31-2020, 02:13 PM
Fuse....too small ?
08-31-2020, 02:49 PM
You have to make sure that the blades of the fuse touch both contacts inside the 7-way connector.
Gotta go campin!
08-31-2020, 03:08 PM
Sticking an ATC/ATO fuse into A & B terminals is not ideal. The fuse spades are horizontal, but the terminals on the cord are canted. Often times the two will not mate (make contact), or the fuse gets twisted and snaps the spades loose from the fusible link. Use a inline fuse holder and crimp spade connectors on the ends of the wires.
2016 Salem 27RKSS
08-31-2020, 03:17 PM
One other important thing: Make sure you have 12V on terminal 4.
2016 Salem 27RKSS
08-31-2020, 03:23 PM
Most everyone I know just uses a standard size flat fuse in the top of the 7way (slots 3 and 4). Some just a wire, as it doesn't have to be a fuse.
The 'trick' gets old fast
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
08-31-2020, 03:41 PM
I just use a #12 wire with 2 male spades crimped on. My total amp draw with all LED running lights is about 0.4 amps. No fuse required. Total cost: $0.50 in materials, and about 90 seconds of labor, LOL.
No real reason to do it except to have fun and create an ambience. Usually around here everyone does it during Halloween when the kids are going around the campground Trick-or-Treating.
Have a great time with it!!
Brian & Becky
2018 Avenger ATI 27RBS
08-31-2020, 03:45 PM
Yes fuse good. What else can I check? Any ideas appreciate
08-31-2020, 03:48 PM
Yes fuse good tried several. I am plugged into land line. Don't know why not working. Tried fuse and a cap from on internet with two prongs works like fuse joining 3&4
An automotive flasher between the pins will make the lights flash!
And yes... it gets old quick.
08-31-2020, 03:51 PM
Test for 12v on pin #4 with a multimeter or 12v test light.
08-31-2020, 03:58 PM
Oh wow, that would get old quick!
Brian & Becky
08-31-2020, 04:00 PM
With all that said, you probably don't have 12V on connector 4.
2016 Salem 27RKSS
08-31-2020, 04:30 PM
Not much use for it here in Alaska with our daylight hours during camping season, but it does come in handy for checking lights without the TV.
2016 Salem 27RKSS
08-31-2020, 04:37 PM
I always recommend that RVers use a short loop of insulated 12 awg solid wire to keep it simple. Makes it easier for neighbors to jerk it out while the guy desiring lights is snoozing.
AS D W suggests, I have used a loop to test running lights after Wildcat service made a skirt repair that affected a couple of side lights.
08-31-2020, 05:16 PM
Why would you you need all those lights on anyway?
08-31-2020, 05:17 PM
For fun
08-31-2020, 06:09 PM
Originally Posted by NMWildcat
For fun
Unless you're trying to sleep next to them.
I think it's more "Look at me"![emoji37]
08-31-2020, 09:32 PM
Originally Posted by Mtelkman
It is definitely a "look at me" idea. Making it bright in the campground when people are trying to enjoy the night sky or try to sleep, etc. is a jerk move.
Not everybody is in a campground, and not everyone who does it is a jerk. Some folks are real touchy though.....
