Old 06-27-2020, 01:11 PM   #1
Sizes of our gray tanks
Our 2020 22RBHL is listed as having a 64 gallon total gray tank capacity. There are two tanks - a front for the kitchen sink and a rear for the bathroom sink and shower. Would anyone happen to know the sized of each tank? Are they equal in size? Larger for the bathroom and smaller for the kitchen? I ask because we have only taken the camper out once and it felt like the rear bathroom/shower tank filled up quicker than expected. Our last camper had a single 26 gallon gray tank and we rarely filled it up but with this camper we barely pulled off the weekend and it was already 100% full. Surprising for only 2 people who are generally conservative with our water use. I reached out to Forest River directly and they couldnít help me at all (right???) so not sure where to go for this information.
2020 Heritage Glen 22RBHL
Quadna71 is offline   Reply With Quote
Old 06-27-2020, 01:44 PM   #2
Originally Posted by Quadna71 View Post
. Our last camper had a single 26 gallon gray tank and we rarely filled it up but with this camper we barely pulled off the weekend and it was already 100% full. .
How do you know the tank was 100% full? Are you relying on the panel lights or did you hear water sloshing in the shower?
If Forest River and the dealer doesn't know the capacity, you might have to measure it yourself.
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 06-27-2020, 02:09 PM   #3
Given that you have a 32 gal. black tank and 64 gal. combined gray capacity, I'm thinking that you likely have two 32 gal. gray tanks.
We have a Rockwood 2606WS with the same floorplan as your 22RBH regarding the mid kitchen and rear bath, and we have three 37 gal. tanks.
2017 2500HD, WT, DC, 4x4, 6.0
2018 Rockwood 2606WS
2whlzstan is offline   Reply With Quote
Old 06-27-2020, 03:08 PM   #4
Both - lights said it was full and you could see the water level up to the drain.
Old 06-28-2020, 08:41 AM   #5
Hmmmmm... you seem to have a puzzle on your hands. You could take it back to the dealer, but you'll probably be met with puzzled expressions. That would be worth a try. Maybe their techs will have an explanation. Or.....
You could do some investigation on your own. If you use a water meter, you could see how much water it would take to fill each tank.
https://smile.amazon.com/Save-a-Drop..._t1_B0187BOFD6
It's possible you don't have as much capacity as advertised or there might be a connection between the two tanks that's causing one to fill faster than normal, or the shower head is not as efficient as your previous trailer or something is blocking the draining inside the tank....or something else....
Old 06-28-2020, 11:24 AM   #6
Maybe it wasn't empty when you brought it home.
2011 Flagstaff 831FKBSS
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 06-28-2020, 03:12 PM   #7
"Curmudgeon"
Send a message via MSN to Trawlerphil Send a message via Yahoo to Trawlerphil
Most hardware stores have a little meter that goes on to your water hose and tells you how many gallons pass through. The best way to find out the size is to empty the tanks and measure how much water they take.
_____________________
TrawlerPhil
2014 Flagstaff Classic Ultralite 8528RKWS
2012 Tundra 5.7
2020 Tesla Model Y
Trawlerphil is offline   Reply With Quote
Old 06-29-2020, 01:03 AM   #8
Tom48's Avatar
Drain everything, then use a hose end water meter and fill them. I find the meters to be fairly accurate.
https://www.amazon.com/Orbit-56854-H...49413728&psc=1
Tom48
In Sunny So Cal /w
Now in 2005 Holiday Rambler Ambassador DP and The Hot Air Balloon RESTLESS
NO MORE Tricked out
2017 Sandstorm 250 T.H.
Tom48 is offline   Reply With Quote
Old 10-15-2020, 11:04 PM   #9
If you donít have a sealed bottom, and your tanks are exposed, you can crawl under the coach and look at the tanks. They are usually molded with the manufacturers name and either capacity or dimensions. You can then go to the tank manufacturers site and get the capacity. I have a 2021 Wildwood X-Lite 273QBXL, and based on the manufacturers brochure, we thought we had a 60 gallon gray tank. Since this unit can potentially sleep 11 people, that seemed adequate. Well after our first trip with 2 adults we filled the tank in a couple days! Come to find out, Forest River decided to change the gray tank capacity to 30 gallons. Donít trust the marketing brochures for any specifics.
2021 Wildwood Xlite 273QBXL
2014 Ford F-150 Super Crew
C170 is offline   Reply With Quote
Old 10-16-2020, 06:24 AM   #10
Thanks but our RV is sealed across the base. I think weíve come to terms that we donít know the amounts and I guess thatís okay. So long as we get used to the rate in which we fill the tanks up. Weíve had a few more long weekends under our belt since then and are starting to get a feel for how much or little water we can get away with using.
Old 10-16-2020, 01:44 PM   #11
Sunflower0527's Avatar
Very possible. They had filled our fresh water tank for the walk through. What goes in, must come out.
2021 Wildwood Heritage Glen Elite 36FL
2012 Ram 3500 6.7 diesel dually long bed
Sunflower0527 is offline   Reply With Quote
Old 10-24-2020, 01:12 PM   #12
My WW 273QBXL has a gray tank capacity listed at 30 gal.
I crawled under Camper and found stamp on the blow molded tank . It is 22”x54”x8” ... (1.833’x4.5’x.667’) = ~ 5.5 lb3. 7.48 gal / cubic foot = ~ 41 gallons.
I guess that’s outside dimensions on the stamp. ?
Nonetheless, all math aside. We were on our first trip in a camper ever. I assured the gw tank was empty via drain. All empty. I ran kitchen and bathroom sinks for a minute to check that water was working properly. Wife washed a bowl and some silverware for about two minutes after dinner. Then my son took about an eight minute shower then wife took an eight minute shower and the level lights were showing full and the water was up to the drain in shower. I dumped the gw tank and it drained solidly for about a full minute out of our big drain hose. I cannot for the life of me believe that was 35 or even 30 gallons. Does this make sense to everyone else on here?
matemike is offline   Reply With Quote
Old 10-24-2020, 01:22 PM   #13
"Curmudgeon"
The best way to measure the tanks is to get a little meter that goes on the end of the water hose. Empty the tank, close the valve and fill the tank to get the total gallons passed out the fill hose.
TrawlerPhil
2012 Tundra 5.7
2020 Tesla Model Y
Old 10-24-2020, 02:03 PM   #14
dieselguy's Avatar
16 minutes worth of showering can use more water than you'd think depending on what shower head you have. Some of us seasoned RV'ers take what is called a "navy shower" which greatly extends how long you can rely on your grey water capacity. Turn the water on, spin around a couple of times, turn water off. Soap up. Turn water back on, spin around 2-3 times and call it good unless you're washing your hair. The 15 plus minute showers we have all become accustomed to in our homes only works out sucessfully when you are at a full hookup site in an RV.
dieselguy is offline   Reply With Quote
Old 10-24-2020, 02:34 PM   #15
KyDan's Avatar
Was it actually full or are you going by the lights on the wall?
It's not full until it backs up in the shower.
Easy test, get a 5 gallon bucket. Pour 4 gallons in there as measured with a milk jug. Mark it at 4 gallons.
Pour this down the drain.
Repeat until it shows up in the shower.
Now you know for sure what you have to work with.
Why 4 gallons? I know there's no way I'm gonna carry a full 5 gallon bucket and not spill it everywhere!
Happy Camping!
Peace!
Dan & Rita D
Blue Ox WD hitch
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32, 2020-41
Old 10-24-2020, 06:26 PM   #16
Experiment:
Used a large measuring cup to measure 5 gallons in a large clear tote and marked it on the side of the tote.
Drained gw tank to completely empty.
Yup. Took exactly 6 totes at 5 gals each til the shower would no longer drain.
What was a bigger eye opener for us was that the shower took exactly 2m:30s to reach the 5 gals mark.
2 gallons per minute flow rate. Turns out 15 minutes of showering will fill a 30 gal tank.
Learning as we go. ..ain’t this stuff fun!
Old 11-11-2020, 11:59 PM   #17
Matemike, that works for me. We have experienced a similar conundrum with our 233RBXL. It is listed at 32 gal gray water. After 2 "semi-navy showers", 3 dish washings, and misc glasses of water/teeth brush, etc. and the lights showed full tank. I did not see water in the shower drain, though.
I was working on a plan to measure the capacity and checking when the lights change. Your method will work! I am going to try it next time out. I will post my findings when I get them. - sorry, not gonna do the same with the "other" tank......
Thank you!
2021 Wildwood X-Lite 233RBXL
2016 Dodge Ram 1500 Laramie Longhorn
(Yes, it is big enough to tow safely)
Tradclimber is offline   Reply With Quote
tank
