09-25-2022, 08:02 PM
Slide out controller
Hey all,
I’ve got a 2021 FR Wildwood 27RE. My slide outs work sometimes but pretty rarely. I’ve checked all the fuses and the wires running to the switches, everything looks good. I can’t figure out if this model has a slide out controller anywhere. Any help would really be appreciated.
09-25-2022, 08:30 PM
Moved thread from the General Tech and Repair section to the Wildwood sub-forum since the OP is asking for model-specific information, the location of the slide controller in their Wildwood trailer.
Sent from my SM-G781U using Forest River Forums mobile app
09-25-2022, 09:33 PM
Owner’s and equipment manufacturer manuals
Originally Posted by buyacampertheysaid
Hey all,
You might be able to get information on your unit here;
https://forestriverinc.help/#/forest...travel_trailer
2018 Flagstaff Super Lite 29RKWS
1999 Ford F-350 Crew cab 7.3 diesel SRW 4x4
09-25-2022, 09:41 PM
Perhaps a bad switch? pull the switch out and bypass it, see if that works.
2021 2205S Rockwood Minilite
2019 F 150 Lariat 3.5 Eco Fx4 Max Tow
Equal-i-zer WDH, 1809 lb payload
09-25-2022, 09:43 PM
SCHWINTEK Slide controller
If you look at side of slide and it has an aluminum rack at top and bottom, it has a SCHWINTEK controller. Our Flagstaff Super Lite has the controller in the pass through storage. It’s only about 3”x4”. It has an LED for fault codes. There’s a troubleshooting manual in the owners manual section. I haven’t looked into our other slide.
09-25-2022, 10:23 PM
Originally Posted by BRinSCupstate
NONE of those owners manuals have any model-specific nor brand-specific information. If you look at each brand's manual that you linked to, they are exactly the same generic owners manual.
I challenge you to find any documentation in any of these manuals that provides the specific information that the OP is asking for.
09-25-2022, 10:37 PM
It’s definitely not the schwintek, just a lippert above floor I think. And on the lippert site it has a wiring diagram but others have mentioned the diagram isn’t accurate because it doesn’t include anything except the battery and a fuse, not even the extend/retract buttons if I remember right. I’ll probably just try following the wires tomorrow.
09-25-2022, 10:38 PM
I have 2 slide outs and neither of them work. Do you know if it’s common for the switches to be on a circuit together? Or would one switch still work and the other wouldn’t?
09-26-2022, 01:27 AM
If you go to the model, then “Component manuals” and select “Slide outs”, the Lippert manuals are there. Comparing the information in the Lippert manuals could help in identifying what type slide system it has.
09-26-2022, 01:49 AM
In this Lippert manual, there is a component section. A couple show controllers. Maybe you can find your slide by comparing the diagrams to your slide.
https://s3.amazonaws.com/cd-content....d9a6647045.pdf
If you have the controller and can locate it, it looks like a good location to check for battery power and function of the switch. Seems odd neither work. It seems like you’re missing 12v power to them.
09-26-2022, 02:21 AM
Go to this manual and try to determine which above floor model it is. Both double rails seem to have a controller.
https://support.lci1.com/lci-above-floor-slide-outs
09-27-2022, 09:36 PM
Slide switch for Wildwood 36 BHBS travel trailer
This camper was renovated when I bought it. The bedroom built in desk/chest had been removed and the wiring for the slides that were once mounted to the side of the desk were taped and just sticking out of the wall. We put a switch on the 4 wires which turned out to operate the front slide. However the wiring for the bedroom slide is still a mystery. There isn't a second hole in the wall for another switch. The only thing I can imagine is that there is another set of wires inside the wall. Does anyone have any answers to this mystery?
09-28-2022, 02:29 AM
You posted in someone else's thread about their Wildwood trailer's slide controller, that they posted in the Wildwood sub-forum.
Do you also have the same Wildwood model that the OP has? Your questions are not what the OP was asking about.
You haven't provided any information about year, make and model number of your RV.
