Old 03-22-2017, 10:17 PM   #1
Slide out, stabilizers, awning and front jack not working.
I have a 2014 wildwood and my slide out, stabilizers, awning and front jack have stopped working. When you mash the switch you can hear the motors engage but there is no movement or just a very slight movement. I have connected to 110 and also connected to the truck while it was running. Fuses and breakers are good in the box. The inline fuse from battery to front jack was good but I even put a new one in jury in case. Are there any fuses or inline relays from the battery back to the camper I am missing? Seems like there has to be.
Qcrew is offline   Reply With Quote
Old 04-01-2017, 09:38 PM   #2
Don't assume you are getting full voltage at the motor, check it with a meter.
If yours has a remote, the a control board with relays and fuses somewhat hidden. Posting which model you have may get you more help.
2016 Wildwood 32BHDS
2004 F-250 CC 4X4 V10
Mars is offline   Reply With Quote
Old 04-05-2017, 11:41 AM   #3
sounds like a low voltage issue. If you hear the motor engage but it cannot drive the motor then it means you have power (not a fuse issue).
If you have tried on 110V power and truck power, then it might mean you have a short somewhere that is pulling down the voltage when you turn the items on.
Maybe try measuring the voltage at the fuse before and during pushing the button?
mkosu04 is offline   Reply With Quote
awning, slide, slide out, stabilizers
