I'd be running them at the cold max pressure. 65psi. No less than 60. Check inflation pressure when the tires are cold.
Check and adjust the tires before every trip. Daily, if you're on the road traveling. Do it first thing after the tires have sat and cooled overnight, before hitting the road again.
Monitor the tread surface for uneven wear. If they start wearing a bit more in the center at the higher psi than on the edges, reduce the pressure about 5 psi.
