Old 07-04-2019, 08:49 PM   #41
... and I'm a girl.
We have a Rockwood 2502s and I have the 5x5" fence post mounted on the bumper. I think it looks good... and I'm a girl. I don't want to have to take off the couplings every time I dump so I needed something bigger than the bumper. The spare tire is also mounted on the bumper, which helps to disguise it. I don't have a picture of the bumper but you can just see the end of the white fence post at the rear of the trailer in this picture from last fall. The white tailed doe is free gratis.
Name:	Fall cropped.jpg
Silverbirch is offline   Reply With Quote
Old 07-05-2019, 12:25 AM   #42
Ours are no longer triangles. They got bent really bad the first time we parked it in our driveway. They definitely serve a purpose I’m sure.
DanNancy is offline   Reply With Quote
Old 07-05-2019, 05:59 AM   #43
Former Navy
Former Navy's Avatar
Leave these on...they act as skid plates when you experience a steep incline\decline. Pull the plastic caps off your rear bumper...put your hose inside the bumper. Seriously, it's about all it's really good for LOL!
Former Navy is offline   Reply With Quote
Old 07-05-2019, 06:36 AM   #44
Dave Lyon's Avatar
Originally Posted by billybigrigger View Post
I store my hose in the bumper. I remove the caps and adapters and place them in small container when not in use.
X2
Dave, Southern,ON
2017 GMC SLT HD All Terrain Crew Cab (6' 6" Box) 2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
Dave Lyon is offline   Reply With Quote
Old 07-05-2019, 06:39 AM   #45
Try fore/aft using the frame as support. The hose collapses to quite short. 2 or 3 short 5” boxes could work. You may need to angle one end out to allow clearance for the frame outriggers and hose insert/withdrawal.
Notice mine is ty-wrapped in place as a “temporary” trial. Been there about 6 months. This box holds two lengths of hose and the 90 deg clear elbow with a “gutter drawer”. Elbow is stored loose and must go in with bayonets first to clear the 5” cap retaining bolt. The spacers between bumper and box provide clearance for the spare tire bracket bolts and to minimize rust between box and bumper.
This far better than in the forward storage and odors wafting up to the living area. Hose is not always deployed.
2018 Surveyor 264RKLE
Retired
Location depends on weather and state plandemic rules.
Most coincidences are carefully planned
Jeffjeeptj is offline   Reply With Quote
Old 07-05-2019, 12:02 PM   #46
Originally Posted by forsakentalon View Post
I want another way to store a sewer hose and the best spot is where these are welded. Can I cut those off and put 5x5 vinyl post cover with sewer hose where they are?. I have a 179dbk. !Attachment 208336
Not advisable to cut the triangles off, there purpose is to protect the bumper and any other low hanging items from being damaged or ripped off. If your looking to create a sewer hose storage spot I would recommend putting it on top. Just need to ask, why aren't you storing the hose inside the steel bumper as designed ?
skipatroller is offline   Reply With Quote
Old 07-05-2019, 04:41 PM   #47
bedubya's Avatar
You can have a good welder cut them off and weld squares on in their place, large enough for your 5x5 fence post cover to fit inside. I would beef it up at the same time by using 1/4"x2" bar stock.
'19 Chevy Colorado Z71 4x4 Crew Cab
'17 Salem Cruise Lite 232RBXL
Mickey the Rescue Project Schnauzer
Days Camped: '17-39, '18-61, '19-64, '20-38
bedubya is offline   Reply With Quote
Old 07-06-2019, 04:52 PM   #48
Send a message via Skype™ to Mipo
My way of storing the end part of the hose
Do you have a spare tire above the rear bumper.
If so may be this idea can help.
Check the picture.
Mipo is offline   Reply With Quote
Old 07-07-2019, 08:40 AM   #49
Get a new wife?
--2005 F350 Superduty Crewcab, 6.0, 4wd, short bed, 3.73 gears;
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
phillyg is offline   Reply With Quote
frame
