03-09-2020, 08:34 PM
Upgraded to Dometic 320 Toilet
I did it. Upgraded the toilet in our 2017 Wildwood 201bhxl to a Dometic 320
I cut out a 10" x 8 1/2" section of the wall trimmed out and Installed new Dometic 320 Toilet
Actually gave us more room in the front and on the sides. DW and I both like it.
Sits just like the thrones we have at home.
03-10-2020, 09:46 AM
Neat work a round
Retired Navy
2016 Flagstaff 26 FKWS
03-10-2020, 10:05 AM
Thinking outside the box! I love it
03-10-2020, 10:55 AM
That's pretty ingenious. Looks good.
I've been wanting to change our toilet out to a 320 so I could install a bidet. But in our RV, there's a vent stack ran almost directly behind the toilet, so I'll need to do some investigating to see if cutting a section out would miss it.
Thanks for the pictures. Always getting ideas from things people do.
Gotta go campin!
03-10-2020, 12:03 PM
Nice work, you will be happy with the upgrade too
2022 Montana 3855 BR
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
03-10-2020, 12:04 PM
Is that an outside wall?
03-10-2020, 12:52 PM
Nice job! We wholeheartedly agree, the 320 is the FIRST upgrade we made over the OEM junk plastic camping toilet. We installed the 320 with the sprayer kit on our 2019 Forest River Forester 3041DSF. The clearance was adequate and no modifications were needed. The 320 has the much preferable oval seat and sits higher as well.
03-10-2020, 02:18 PM
Thank you all for the nice comments, at 6’ 1” 225+ lbs needed the larger/higher seat.
My black water vent stack runs up on the left side on the area I had to cut out, pushed it back to the left by about a ½ inch when I put in the ¾ inch by 2 inch piece of yellow pine.
This was on an inside wall, there are a set of bunk beds on the other side.
Thanks, Again
03-10-2020, 04:48 PM
Very nice job!!!!
03-10-2020, 05:26 PM
Our dealer did our upgrade to the 320 before we picked up our new Cedar Creek. You'll especially appreciate it when it comes time to replace the seat and you can pick up a std model from the home center instead of ordering one from Dometic.
03-10-2020, 07:56 PM
We did that, changed 310 to 320 toilet (with the spray kit) and a Bidet. We got the Brondell Swash bidet and absolutely LOVE IT! The elongated seat is sooooo much more comfortable.
My solution was slightly different as far as the rear clearance though.
The part that caused the interference was the ceramic cover behind the seat and above the vacuum breaker.
I used a 4" mini grinder and a diamond wheel to cut the ceramic cover about 1/2" on the top so it cleared the wall. The black you see is black duct tape put onthe toilet to protect it while cutting with the grinder.The solution worked perfectly.
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
03-10-2020, 08:08 PM
Great clean looking install! I upgraded the our plastic toilet with ceramic #310 and love it! Would have liked to have upgraded to #320 but the wall was in the way. Wish I'd seen this before.
05-09-2020, 07:23 PM
Dobbs from WI
I think your mod just made my DW very happy!
07-22-2020, 11:56 AM
2020 FR Wildwood 263BHXL
I have a 2020 263BHXL. How do you tell which Dometic model you have. I hate the plastic seat. I’d like to upgrade
07-22-2020, 12:09 PM
There's a label on the side of the pedestal that has the model on it. However, if it's a all plastic toilet that looks like below then it's a 300.
Gotta go campin!
07-22-2020, 12:24 PM
Ok thanks,
I’ll get down there and check it out
07-22-2020, 01:17 PM
The 300 is cheap plastic that squeaks to high heaven. I upgraded mine to the 310 which is ceramic, solid seat, and no-slam lid which I love!! If you have the space the 320 is elongated and would be the macdaddy but you MUST have the room.
07-22-2020, 02:45 PM
Yes I agree the one I have is plastic and seems cheap. So I believe I currently have the 300.
When I bring the trailer home for a short weekend trip I’m going to measure up for either a 310 or 320
07-22-2020, 05:32 PM
Great looking install. I gave some brief thought to doing that on my TT. Back wall opens up to outside kitchen so I would have room.
Decided however to just install a 310.
I did notice that with the 310 almost all the way to the back the lid and seat don't go back as far when lifted. Do you notice that with yours?
If you and the DW like it, that's all that matters. Happy --------- well, you know what.
07-22-2020, 07:03 PM
Looks great. I upgraded to the 320 a few weeks ago and have only tested it with the water pump. I like the new size and no more creaking 300.
While I have plenty of pressure with the hand sprayer I don't think the water comes out with as much pressure as it should. It kind of just dribbles out. I checked for debris but didn't find any and it was new anyway and the sprayer works just fine on the same line.
Do you see the same issue? Did I miss something in the destructions?
