Old 05-18-2024, 08:15 AM   #1
Water Heater
I just purchased a 2015 Wildwood 28RLDS. There is an on/off switch in the water heater panel on the exterior of the coach and a switch on the interior panel. Which switch does what? Iím hooked up to electric so I donít want it to run on propane. Which position does what on the switches?
ID:	299929   Click image for larger version
ID:	299930   Click image for larger version
Travis423 is offline   Reply With Quote
Old 05-18-2024, 08:18 AM   #2
wmtire's Avatar
This thread will explain it all for your Suburban SWDE water heater. The switch on your panel is ONLY for the gas heating mode. The switch outside on the face of the water heater is ONLY for the electric heating element mode. Please read the link below for the operation of and more advice.
https://www.forestriverforums.com/fo...ore-36197.html
2011 Flagstaff 831 RLBSS
I want to go to Bora-Bora, but Iím too Pora-Pora.
Old 05-18-2024, 10:24 AM   #3
Read the post recommended by WmtireÖ
In your pics you have the gas on and the 120 vac off. You can run both at the same time for quicker hot water recovery but most donít need to unless they have a large family needing showers.
The switch in your panel is for propane operation. The red LED above it will stay lit if the propane does not fire after 3 attempts of the electronic igniter.
So for your case, turn off the switch in the panel and turn on the rocker switch in the heater housing and you will be operating on shore power at not propane.
dalford is online now   Reply With Quote
Old 05-23-2024, 09:52 PM   #4
Just be sure there is water in the water heater tank before turning either switch on.
LP provides faster recovery than electricity. Both switches ON is even faster recovery.
Bob
Bob K4TAX is offline   Reply With Quote
heater, water, water heater
