In the absence of a water service panel, the bypass valve is located on the back side of the water heater. Find the location of the water heater on the outside of your TT, then go inside to that location. Often the back of the water heater can be accessed by removing a false wall panel. Once you open that up you'll find either two or three valves. If you're not sure how to reset them snap a photo and post it up and someone will help out.
Good luck.
2024 Geo Pro 15TB, 400W Solar, 2 Golf Cart batteries
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller, Roadmaster Active Suspension
Wooden Spoon Survivor
