I can not locate the low point drains for the hot and cold. Do I need to remove one of the accessibelly panels? It appears that hot and cold lines connect into the fresh water tank drain valve.
I don't have the vbub, I have the Vbds and I bet the drains are similar. Look up above the water inlet, where the hose attaches. If I lay underneath that spot and look up, both of my drains are right there.
