It is going to be near impossible to get all of your screws into the alum studs...I did not even try, other than to position my panels close enough to the side to leverage the stud there.
I used size 14 Truss head screws. It is key to pre drill the holes, then use a manual screwdriver to not over tighten the screws.
I put EternaBond tape under the mounts, and then lots of self leveling lap sealant on top.
With 4 mounts per panel, with 2 screws each in them, my six panels are going nowhere.
I have a Mini Lite 2509s.
I hope this helps.
