DC. I have a 21FBRS as well but I am sure that appliances and power consumption has changed since my 2017 was built. I got an amp meter and checked the amp usage of everything in the trailer. when traveling, I have the refer running on gas. The base amperage used of the trailer, just sitting, is .17 amps/hour. The refer uses 0.58 amps/hour. Calculated out that is 4.08 amps/24 hours and 13.92 amps/24 hours.
I have two group 24 Deep Cycle batteries, both Walmart but good, they each have 75 amps which is 35 usable amps. Your interstate batteries may not give this many amp hours and they are not true deep cycle. it is possible for your trailer to use 30-45 % of available amps during travel for two days. As other posted said, the tow vehicle does not provide but a trickle charge.
The solar, if working at the best capacity, is going to only give you maybe 3-4 amps / hour. this is in the best of conditions.
As a final though. I turned on all DC sources in my trailer. If every DC source is on, it draws 15.33 amps/hour. this will drain my batteries in about 6 hours...by the math. It does not take but a single lighten, maybe the hood light that uses 1.38 amps or the bath fan that uses 2.67 amps to really draw down the batteries.
