Old 04-26-2021, 07:03 PM   #1
25brds front angle
Just got back from Fort wilderness (Disney world) and decided it was time to modify my front level. The front cap is angled down so much that the acculevel bubble for front to back wouldn't really hold its position.
I made a couple stand off from starboard I had to get it back to level. Figured I'd share in case anybody wanted to use the acculevel but the angle had them worried. By the way I used 21 degrees to compensate for it and came out pretty much plumb.
Lines are drawn to guid me while I drilled the holes for screws to hold the stand off. I drilled a small hole the used a bigger bit to allow the screw head to sit below the surface. Then I drilled the holes for the acculevel.
Don't forget to seal any holes drilled to stop water from leaking in.
ID:	252927   Click image for larger version
Ole_blue is offline   Reply With Quote
