Again, we don't know what R/V you have.
I see it is your 1st post so welcome!
Fill out your signature so we can find it even if you don't post it.
Typically, water heater bypass valves are behind the water heater.
As mentioned they are often behind a false panel or drawers.
Find the water heater on the outside and then visualize where that would be on the inside and start looking there.
On some models, the water heater bypass valves are located in what is called a wet bay. Not all R/Vs have wet bays.
Days Camped ☼ '19=118 ☼ '20=116 ☼ '21=123 ☼ '22=134 ☼ '23=118☼ '24=86
